Home > Technical > Sagging rear suspension
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
My "new to me" 90 has a little bit of a sagging rear end, more particularly on the passenger side where it appears about ½" lower than the other side or the front. I would have expected the rear of an unladen 90 to appear a bit higher than the front Confused
All the springs appear to be in good condition with virtually no surface rust anywhere apart from a little bit where they fit onto the seats. I've checked the spring types against the colour codings and they're the correct ones all round, I've also checked the free length of the one in question which is correct at just under 15".
Is it possible they can just go "soft" with age so they compress a bit more than they should for a given loading?
Post #422885 12th May 2015 12:53pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
In a nutshell - yes.
Sounds like the rears have lost stiffness .... or possibly the front have been replaced with springs in the past of dubious manufacture and/or spring rate?? Guns and Landrovers .... anything else is irrelevant.
Post #422896 12th May 2015 1:45pm
Clive
Thanks for that, it's what I thought really.
They look like they're probably all original, maybe the previous owner used to carry a lot of weight in the back.
I guess I'll start by replacing the "soft" one and see where I go from there.
Now the dilemma begins - OEM or aftermarket ??
I suppose if I go with aftermarket, I'd best replace both the rears together.
Post #422897 12th May 2015 2:14pm
mk1collector
I thought all 90s sat nose high and all 110s sit rear high Ray
My build thread
Post #422905 12th May 2015 2:29pm
consumerize
United Kingdom 2004 Defender 90 2.5 TD SW Java Black
All 90's are nose high, and if I'm not mistaken the springs one one side are longer than the others also. (drivers side i think)
If you want it to sit level you will need lowered springs from someone like Alive Tuning or Twisted.
Post #422936 12th May 2015 4:09pm
Dave-H
That's why i said 'dubious manufacture' ... Recently replaced a front set for someone with Britpart springs [Standard 175lbs] ... And it looks like It's had a 2 inch lift! Definitely way too stiff Evil or Very Mad
Stick with Genuine or quality makers [Bearmach etc] Guns and Landrovers .... anything else is irrelevant.
Post #423010 12th May 2015 8:09pm
