![]() | Home > Puma (Tdci) > botched up stone chip colour |
| Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 288
Are you sure it's not Orkney Grey?
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
Primer affecting colour coat? Does it come with a clear lacquer, if so have you tried using it? Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
To clarify, your Defender looks Orkney & the touch up looks Stornoway.
| andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617
just to be check your vin plate colour code touch up should be a closer match not often as same as process is of batch colours never the same even if same mix
| MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 270
Thank for your advice! My paint code on the chassis plate is 907 which is Stornoway grey. I have two paints now from different suppliers and they are both to dark and really stick out.. Not sure what to do? 1953 80"
1987 mini city e 2011 90" |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Get a stonechip company to do it, there's loads about. It's not expensive and they'll get a perfect match.
| Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 |
If it's any help Stornaway has a white primer
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
I've had little success with paint sticks too.
Airbrush by a professional would be better in my opinion or live with the battle scars. Everything normally tells a story even down to a stonechip. |
| arran jones Member Since: 21 Nov 2016 Location: south west Posts: 728
Hello All,
My paintwork just under my windscreen has got a few stone chips that have turned to little rust spots! Is there any thing that I could spray onto the paintwork(Blue) to stop it and prevent anymore stone chips, I have dinitroled inside through the door hinges but obviously I can't spray that on paintwork, Any comments would be appreciated Arran |
You can get clear protection film from somone like 3M.
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| Sammyboy Member Since: 28 Feb 2017 Location: Hampshire Posts: 121
Had a Stornoway Grey D3 and had exactly the same problem. Never did resolve it!!!
OK thanks custom90
Is it sticky on 1 side, so I just stick it on or do I have to use glue sort of stuff!!?
| X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304
Puzzling this colour match problem...
I had to touch up a few stone chips with Stornoway Grey recently, and painted the heads of a few SS door bolts. I was really please with the colour match, the Lacquer didn't change the colour it just added the gloss finish. For Stornoway make sure it's VEP 501730 LEL Click image to enlarge Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
