![]() | Home > Puma (Tdci) > botched up stone chip colour |
Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 288 ![]() ![]() ![]() |
Are you sure it's not Orkney Grey?
Primer affecting colour coat? Does it come with a clear lacquer, if so have you tried using it? Steve.
To clarify, your Defender looks Orkney & the touch up looks Stornoway.
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 ![]() ![]() ![]() |
just to be check your vin plate colour code touch up should be a closer match not often as same as process is of batch colours never the same even if same mix
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 264 ![]() ![]() ![]() |
Thank for your advice! My paint code on the chassis plate is 907 which is Stornoway grey. I have two paints now from different suppliers and they are both to dark and really stick out.. Not sure what to do? 1953 80"
1987 mini city e 2011 90" |
Get a stonechip company to do it, there's loads about. It's not expensive and they'll get a perfect match.
![]() Treat every day as if it is your last....one day you will be right!! |
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 ![]() |
If it's any help Stornaway has a white primer
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20923 ![]() ![]() |
I've had little success with paint sticks too.
Airbrush by a professional would be better in my opinion or live with the battle scars. Everything normally tells a story even down to a stonechip. |
arran jones Member Since: 21 Nov 2016 Location: south west Posts: 728 ![]() ![]() |
Hello All,
My paintwork just under my windscreen has got a few stone chips that have turned to little rust spots! Is there any thing that I could spray onto the paintwork(Blue) to stop it and prevent anymore stone chips, I have dinitroled inside through the door hinges but obviously I can't spray that on paintwork, Any comments would be appreciated ![]() Arran |
You can get clear protection film from somone like 3M.
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Sammyboy Member Since: 28 Feb 2017 Location: Hampshire Posts: 121 ![]() ![]() ![]() |
Had a Stornoway Grey D3 and had exactly the same problem. Never did resolve it!!!
OK thanks custom90
Is it sticky on 1 side, so I just stick it on or do I have to use glue sort of stuff!!?
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Puzzling this colour match problem...
![]() I had to touch up a few stone chips with Stornoway Grey recently, and painted the heads of a few SS door bolts. I was really please with the colour match, the Lacquer didn't change the colour it just added the gloss finish. For Stornoway make sure it's VEP 501730 LEL ![]() Click image to enlarge ![]() Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
