![]() | Home > Maintenance & Modifications > Chekcer Plates |
| ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 575
K9F,
Thanks for the info, I'll give them a go. Chris 2010 Defender 110 Station Wagon, Santorini Black. |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Chris,
There's a fitting guide I did starting page 3 of this thread. Some of the photos are gone but the gist is still there. If you do commit and need any more info just drop me a 'pm.' http://www.defender2.net/forum/topic7709.h...p;start=30 Treat every day as if it is your last....one day you will be right!! |
As you already have the wingtop chequerplate fitted there is no real need to take the bonnet off. It is easier to get access to both sides when tightening the 28 bolts with the bonnet fitted rather than on the ground or a workbench. Give yourself a fair few hours to fit. Once fitted if you do remove the bonnet it is a two man lift to refit the bonnet I would say. If you go through life with your head in the sand....all people will see is an ar5e!!
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
Two more reasons to have it on the wing tops:
| All times are GMT |
