Home > Maintenance & Modifications > Chekcer Plates
Page 2 of 2 <12
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
K9F,
Thanks for the info, I'll give them a go.
Chris 2010 Defender 110 Station Wagon, Santorini Black.
Post #407085 12th Mar 2015 10:13pm
K9F
Chris,
There's a fitting guide I did starting page 3 of this thread. Some of the photos are gone but the gist is still there. If you do commit and need any more info just drop me a 'pm.'
http://www.defender2.net/forum/topic7709.h...p;start=30
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #407110 12th Mar 2015 11:57pm
ChrisCM
K9F,
Thanks for the link, very informative, It's a lot more work than I thought but a great looking job at the end of it, interesting what You say about the weight of the bonnet after its been CP'd, I had thought of taking it off to do the job, I was thinking, bit of ally sheet cant weigh that much Embarassed
Thanks again,
Post #407186 13th Mar 2015 9:59am
K9F
As you already have the wingtop chequerplate fitted there is no real need to take the bonnet off. It is easier to get access to both sides when tightening the 28 bolts with the bonnet fitted rather than on the ground or a workbench. Give yourself a fair few hours to fit. Once fitted if you do remove the bonnet it is a two man lift to refit the bonnet I would say. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #407190 13th Mar 2015 10:03am
Two more reasons to have it on the wing tops:
Post #408351 17th Mar 2015 10:00am
Page 2 of 2 <12
