|  | Home > Maintenance & Modifications > Chekcer Plates |
| ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 575      | K9F,
 Thanks for the info, I'll give them a go. Chris 2010 Defender 110 Station Wagon, Santorini Black. | ||
|  12th Mar 2015 10:13pm |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | Chris,
 There's a fitting guide I did starting page 3 of this thread. Some of the photos are gone but the gist is still there. If you do commit and need any more info just drop me a 'pm.' http://www.defender2.net/forum/topic7709.h...p;start=30  If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  12th Mar 2015 11:57pm |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | As you already have the wingtop chequerplate fitted there is no real need to take the bonnet off. It is easier to get access to both sides when tightening the 28 bolts with the bonnet fitted rather than on the ground or a workbench. Give yourself a fair few hours to fit. Once fitted if you do remove the bonnet it is a two man lift to refit the bonnet I would say. If you go through life with your head in the sand....all people will see is an ar5e!!
|  13th Mar 2015 10:03am |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018      | Two more reasons to have it on the wing tops:
   Click image to enlarge   Click image to enlarge | ||
|  17th Mar 2015 10:00am |
| Posting Rules
