Home > Maintenance & Modifications > 7 pin to 13 pin conversion
Busboy
Hi members
I am after some advice please, I have the 7 pin tow electrics already fitted to my 110 but i want to charge my battery through the tow electrics socket and have read that a 13 pin is needed, so if I get one will it be plug and play? If not are there any decent installers who know what they are doing in the west London area...... Thumbs Up
thanks for any assistance. ... Steve
Post #405019 6th Mar 2015 4:03pm
gilarion
Unless you also have a 12S socket fitted as well as a 12N it is quite an involved job. Yes you can rewire a 12N easily enough into the terminals in a 13 pin socket. However there is no live feed for battery charging from a 12N socket, so you would need to wire one into the 13 pin you will also have to install a relay and have it switched from the live side of the ignition. If you do have a 12S fitted then the wire from terminal 2 is the ignition positive feed for battery charging.
If you do have both sockets fitted then it is just a matter of fitting the wires to the relevant terminals of the 13 pin although they are very close together.
13 pin Plug
13 Pin Socket
 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #405020 6th Mar 2015 4:13pm
Busboy
I may have answered my own question , just been underneath the wagon and about 2 foot along the loom from the socket end is a grey plug connection. There seems more wires in the other sides connector than on the tow socket side. So hopefully it is plug and play. Bow down Steve
Post #405025 6th Mar 2015 4:25pm
gilarion
Usually 12N sockets are wired with cable in a black sheath and 12S are wired with cable in a light grey sheath Thumbs Up
Although new 13 pin multi core cable is also sheathed in black. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #405026 6th Mar 2015 4:27pm
Busboy
Hi gilarion
Thanks for your reply, I've only got the one socket with a black cap if it makes a difference. Steve
Post #405030 6th Mar 2015 4:31pm
gilarion
If you have a grey socket connection which will be for a 12S socket then it looks like all you will have to do is feed the core cables from that connection block to the new 13 pin socket following the wiring diagrams given. If you have to join the cables with a new length of wire make sure you use good quality connectors and not those awful scotch block things. It may be possible to buy the socket feed with the right connector to connect to the connector you have that would make it so much easier. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #405033 6th Mar 2015 4:39pm
gilarion
What year model is your 110 as there are wiring kits available from Land Rover for wiring a 13 pin and also a 12s but their part numbers differ depending what model and year. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #405037 6th Mar 2015 4:48pm
Busboy
Yeah it's on an 11 plate gilarion. Steve
Post #405040 6th Mar 2015 4:54pm
The 12N socket is plug and play and is what you describe.
The 12S wiring is not fitted as standard but is what you need to do what you want. It is reasonably involved to add the 12S wiring and involves wiring back to the battery box and taking an "ignition on" signal from inside the dash.
If you had both 12N and 12S, you could very easily fit a fully-wired 13 pin socket. With just the 12N, you could easily fit a partially wired 13 pin socket which would be fine for towing a trailer, but not for what you want.
Post #405044 6th Mar 2015 5:06pm
Busboy
Blackwolf
thanks me being a clueless git I hope I can plug and play, just need to know the best place to get the kit... obviously OEM would be great but with the LR price tag there must be a good alternative. Steve
Post #405060 6th Mar 2015 5:36pm
gilarion
OEM 13pin wiring harness LR005919 Price £110.40 inc VAT
http://www.paddockspares.com/lr005919-kit-tow-bar-electrics.html For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #405065 6th Mar 2015 6:08pm
Busboy
Thumbs Up Thumbs Up Thumbs Up cheers boss Steve
Post #405082 6th Mar 2015 6:58pm
PaulMc
The kit can be bought from MPS Trading on eBay, for £99.99 incl. delivery -
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...1023475683
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #405120 6th Mar 2015 8:08pm
Busboy
Cheers Paul...... Steve
Post #405131 6th Mar 2015 8:30pm
Busboy
I've brought the 13 pin kit now,so my question is is it easy to fit? I already have the 7 pin system fitted on an year 11 plate.
An idiots guide would be very helpful Thumbs Up Thumbs Up Steve
Post #411603 28th Mar 2015 8:16am
