![]() | Home > Td5 > Leaking door |
Have you got a wider picture because I can't work out where that is
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Is it the joint between the upper and lower halves of series/ military doors ? 2005 Td5 90 XS
Steve |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 605 ![]() ![]() ![]() |
Looks like the seal between the windscreen frame and bulkhead, just below that there is a gutter which collects rain water and lets it just drop off onto the door right where it curves out. Could be wrong?
edit: looks like they are at the same level edit: nope Last edited by mrd1990 on 26th Feb 2015 5:58pm. Edited 1 time in total |
Fullfat Member Since: 30 Apr 2014 Location: Lincolnshire. Posts: 271 ![]() ![]() |
Hi yes it between the door and door top,
Thanks ![]() Click image to enlarge |
I'd say it was either the wrong way up or something because as you say that will just catch water and channel it in to the door.
I've just tried to find pics of split doors and none of the pics had a seal with a lip that went up on the outside like that.
Don't remember my series having that lip,but it was a long time ago ! 2005 Td5 90 XS
Steve |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5138 ![]() ![]() ![]() |
All I recall is that the doors had a galvanised bevelled strip along the join of the top and bottom of the door but do not remember any rubber strip For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
No my mistake they do have one and that one I am sure is not fitted right or is so old it has lost its shape
![]() . For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
I'm sure it's designed to angle the door top back slightly, just seems odd the lip is on the outside would have thought it should be the other wAy around, think I will buy a new set and try them the other way
Cheers |
