Home > Td5 > Leaking door
Fullfat
1999 Defender 90 Td5 HT Rioja Red
Leaking door
Hi does this door seal look the correct way around, I keep having leaks and it occurred to me the ridge is on the outside channeling water into the door seal?
Thanks
Post #402437 26th Feb 2015 4:55pm
mk1collector
Have you got a wider picture because I can't work out where that is
Post #402450 26th Feb 2015 5:44pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Is it the joint between the upper and lower halves of series/ military doors ? 2005 Td5 90 XS
Steve
Post #402452 26th Feb 2015 5:52pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
Looks like the seal between the windscreen frame and bulkhead, just below that there is a gutter which collects rain water and lets it just drop off onto the door right where it curves out. Could be wrong?
edit: looks like they are at the same level
edit: nope
Post #402454 26th Feb 2015 5:53pm
Fullfat
Hi yes it between the door and door top,
Thanks
Post #402456 26th Feb 2015 5:57pm
mk1collector
I'd say it was either the wrong way up or something because as you say that will just catch water and channel it in to the door.
Post #402464 26th Feb 2015 6:40pm
mk1collector
I've just tried to find pics of split doors and none of the pics had a seal with a lip that went up on the outside like that.
Post #402466 26th Feb 2015 6:47pm
Lou Sparts
Don't remember my series having that lip,but it was a long time ago ! 2005 Td5 90 XS
Steve
Post #402467 26th Feb 2015 6:49pm
gilarion
All I recall is that the doors had a galvanised bevelled strip along the join of the top and bottom of the door but do not remember any rubber strip For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #402470 26th Feb 2015 6:56pm
gilarion
No my mistake they do have one and that one I am sure is not fitted right or is so old it has lost its shape
. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #402473 26th Feb 2015 7:02pm
Fullfat
I'm sure it's designed to angle the door top back slightly, just seems odd the lip is on the outside would have thought it should be the other wAy around, think I will buy a new set and try them the other way
Post #402547 26th Feb 2015 9:24pm
