![]() | Home > Maintenance & Modifications > Will rear window trims fit with mud rear side panels? |
TDCi Guy Member Since: 17 Aug 2014 Location: Yorkshire Posts: 286 ![]() ![]() ![]() |
Just wondered whether anyone had managed to fit the CSW trims which go around the little windows either side of the rear door into a HT with the MUD side panels fitted?
I've recently fitted the MUD panels and just need to do something with those rear window panels to finish it off. If anyone has any other ideas they'd be greatly appreciated too. Tom @tditomprice 100” Defender Hybrid 2010 Alaska White 90 HT |
Les Brock Member Since: 20 Mar 2012 Location: Stroud, Glos Posts: 186 ![]() ![]() |
Bit awkward but here's mine
![]() ![]() Click image to enlarge Regards Les |
Err........Pic was ok this end
Thanks for those Les! I'm guessing that finishing strip is where you've had to cut the panel? Tom
Les's trims are TD5 of course not Puma
TD5 trims will fit a Puma, no problem (assuming you have no rear seatbelts) I just wanted to point it out as Puma panels are quite different and are missing the part nearest the outside - So TD5 panels would probably suit better
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2074 ![]() ![]() |
Do you have rear windows in your 90 HT or is it just to look nicer inside?
Steve |
Yeah the TD5 panels will fit mine no problem, I don't even have the small rear windows in mine, I was just going to carpet/put something useful in the window hole.
Les I recognised your name from LR4x4 so popped over there to look on your build thread and saw the relevant post. Very useful! Looks like you're almost there with your very meticulous project too, all the best! ![]() @tditomprice 100” Defender Hybrid 2010 Alaska White 90 HT |
Thanks for the reply
I'm following the rear HT threads so I know how to do mine when the time comes. ![]() |
Thanks Tom
I've tried to go the practical route while keeping it as 'plush' as possible. I managed to get the full rear rubber load liner thrown in with the purchase, I've fitted the rear headlining piece and wired in the interior light and also fitted a bulkhead removal bar. Obviously now I have the MUD side panels and I'm looking to finish off the rear window panels. I've also ordered some proper automotive carpet to cover anything that is still bare paint in the rear, after that I think the rear is pretty much finished. Most of the above is documented in my build thread with shoddy pictures to go along with it. Tom @tditomprice 100” Defender Hybrid 2010 Alaska White 90 HT |
