![]() | Home > Maintenance & Modifications > Safari Equipment R & T Sliders. |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
I've got the Entreq door sills/entrance strips and fitted a length of extrusion (pretty much the same as the door seals) along the bottom edge of the strip before offering the slider up.
No shims or packers supplied or needed on a 90.
| Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087
Most excellent Mal... You did it... Where there's a will hey... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
| Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5895
Bowler sills..... I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
I did indeed Venomator.....
| Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000
Thanks Andy
I knew about the extra bar - but it seemed that some sliders sit further in than others ... I'd like some without the tree bars on - but ideally would like them to sit flush like the standard sill does.
And that's another story for another day... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
| Windowlicker Member Since: 24 Aug 2014 Location: East yorks Posts: 290
They look great, very similar ( visually ) to mine , I do not quite know how they vary from one to another, though I do know mine were not galvanised , which I wish they were.
When got mine , I got a mate to paint the box section parts in body colour , as one thing I really didn't like was the way, that when fitted ( or not fitted, just minus the original sills ) it made the truck look a bit odd, where the wing bottom, door and rear quarter basically just stopped , in a sort of unfinished way. Having painted them , it gives the visual impression of the original sills, but with the sliders sort of sprouting out of the box. I also fitted a C section adhesive seal onto the box part , then fitted the sliders into place , had to have a few attempts, so as to get the line visually correct, and account for panel oddities. The end result is so much neater, more factory looking than the obvious gap that was there with them fitted minus seal. Also cut down/re shaped the mudstuff dirtDfenders, as I bought them before the sliders , realised they wouldn't fit , but as I had ripped all the packaging they couldn't be sent back, so just attacked with a blade, dremmel, and sandpaper, then got them painted also. The gripper tape I fitted is 50mm wide, and is the remains of a roll I got with my D3 sliders. Rather than have a 90deg square edge to it, (which looks crap, and leads to the corners lifting) I got a repairwasher that wash the same width, though an aerosol orang appropriate radius will do, and with a blade cut around them,leaving a nice semi circular finished end to the tape, then similar for the laterals sticking out x2. Gripper tape... Click image to enlarge Click image to enlarge Seals.... Click image to enlarge Click image to enlarge Others... Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge "Procrastination is the thief of time" |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
That's not going to please the OP if he doesn't get some protection on them first |
Great attention to detail there Windowlicker ....
Can you explain a bit more about the C section seal ? Did you for it into the back edge of the slider so it concealed the gap above it ? |
| mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109
I have a pair on mine from S E good kit
Hi Ander,
As when I first fitted the seal, I messed around a bit finalising the position , were I to do it again, I would pretty much final fit the sliders, then when happy that they are staying "just" there, I would either chalk or felt tip a line longitudinally following the panels bottom. Then remove the slider ( degrease with brake cleaner or similar , the slider ) then warm up the paint if very cold, and sit the roll of C section seal on the radiator first before fitting. This seal was 14mm C section, 3M adhesive backing and very supple. It just deforms/squashes when compressed, and pops up and in fills the gaps where needed. I couldn't live with it not fitted , as the gap just looks bizarre and very unfinished if you see what I mean. I also used the same seal, to run the full underside of the bonnet also,which nicely seals against the wing tops when bonnet is shut and stops loads of crap/water getting into the engine bay. I have been calling it C section seal, when it was in fact D section !! Duhhh This is pretty much what I bought, though I thing I got 2 lots of 4 metres , as it's cheap enough, and handy for allsorts. http://www.ebay.co.uk/itm/4M-D-type-Door-R...5d519b207c Cheers, Nick "Procrastination is the thief of time" |
Great idea
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
We have supplied the Safari Equip Rock sliders and Rock and Tree sliders in mild steel, galvanised and the standard finish which is galvanised and powder coated for 90s, 110's and 130's. There is a difference in the R + T sliders between say 110 SW/HT/USW and 110 double cabs and HCPU etc.
We keep the standard 90 and 110's R + T sliders in stock. Others we get to order. Luckily the factory is only a couple of miles away from us Please note we are always dealing with Land Rover build tolerances. Brendan |
| All times are GMT |
