![]() | Home > 130 > It's started, Longshanks will no longer be a Pick up |
Looking good.
chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559 ![]() ![]() ![]() |
that will be a tidy install. nice one.
DiscoStu Member Since: 30 Jun 2007 Location: London/The far north Posts: 255 ![]() ![]() ![]() |
Looking good
![]() Bulkhead holes a good idea - I eed to get a lot of wiring through there, will look at your idea My Disco 'best bits' Defender 110 XS CSW 2013 |
Just a pointer....
If you are making extra holes in your vehicle to run cables through these are in my opinion the best Marine Grade cable glands you can use. Any good chandlery should be able to source them for you. Especially ideal if the cable exit/entry is visible too. Not cheap but what value do you place on quality? ![]() http://www.indexmarine.co.uk/cable-glands.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Tidy
I tend to use industrial ones that are used in 300 Bar washes - they seem to do the trick
![]() Defender 110 XS CSW 2013 |
Normal cheap skintop plastic ones also do the job too but are not low profile. Depends on the application and what 'type' of finish you want to achieve I suppose. If you go through life with your head in the sand....all people will see is an ar5e!!
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 ![]() ![]() ![]() |
He did the same with me, what a @£$%&*%! I love watching this build! Peter 2008 SWB Truck Cab 1952 80" Soft top |
Cracking on with the wiring for the extra bits and pieces
![]() ![]() Click image to enlarge |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
Oh lord, is this the result of someone stealing your head unit?!!!!
Oh my...... got more things to fit, will it ever end
![]() ![]() ![]() ![]() ![]() Click image to enlarge Last edited by AndrewS on 13th Jan 2015 9:56pm. Edited 1 time in total |
Go on then, I'll help you out and take them off your hands
![]() ![]() Defender 110 XS CSW 2013 |
You need a 130 for these Stu they are 'Man Brakes'
Man brakes? Try an XJR, they're man brakes! Not adverse to a 130 though, so happy to take that off your hands too
