| Terryt Member Since: 28 Jun 2012 Location: Lerryn. Cornwall. Posts: 750
How is it mate ,got a 90 and torn between this and the tufftek 90 one. Thanks in advance Terry |
| Kent_keith Member Since: 01 Jun 2014 Location: Kent Posts: 388
http://www.paddockspares.com/boomslang-per...-loom.html Quite a price differance between the two though? 2005 TD5 90 CSW XS |
I'll follow that thank you |
| Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501
Did it arrive in a blue box per chance Steve |
| couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830
^^^ from what I can tell from the pictures, all these kits seem to be the same (apart from the price). I have a Bluesea fuse panel, so will connect the power to that rather than the inline fuse holders in the kit.
For the price, I couldn't buy the cable and connectors, so can't complain. Cheers Simon |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
one reason I fused each side individually so I didnt lose both headlights ( made my own loom ) |
I agree they do look the same, well done spotting that |
What current capacity fuses did you use for each side please |
Playing with thermostats , 2nd experimental one
think I put 20amp ones in , but really you could go bit lower , but std fusing is 10a dip beam for each side 10a high beam for each side so 4 fuses in all trouble when you relay your running both dips beams togather and both high beams together on the one fuse with the loom you buy not really the way to do it best way would be 2 looms and cut one side off , , but works out expensive way to do it !! |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939
My 3rd Defendoor arrived today, must find a way of securing it so it doesn't fly off in transit or go walked too easy before fitting it this time.
| Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087
Don't forget to mark it with SMARTWATER then Steve...
At least the police will be able to trace the owner if it does fly off in transit... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
| redhandluke Member Since: 02 Jun 2013 Location: Northern Ireland Posts: 243
Just had a new Twisted 18 inch rim delivered for a spare
Steve |
| shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347
I did see 158000 but was on the motorway so didn't want to risk the photo.
However when I stopped for fuel the 13 year old in me couldn't resist the photo. Click image to enlarge Neheheheheheh Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
