Page 755 of 1392 <123 ... 754755756 ... 139013911392>
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
No sorry no pics, was trying to do it quick as was a bit parky here on the coast !
But it really is easy just remove headlights, I wired mine from the nearside light and ran the wires to the offside lamp going under the bonnet slam panel by removing the fan shroud to gain access and secured with a couple of cable ties, the wiring is long enough to do this,for earth I used the radiator bracket bolts that go into inner wing,cleaned these up with a bit of emery cloth and sprayed with WD40. The live was run direct to the battery I used some shrouding for this wire that was not with the kit as I don't want this to chafe through in the future this was cable tied to air con pipes and then to the loom that runs along the chassis rail and in to the battery box. A couple of cable ties to secure the relays and fuse out of harms way and time to test. All working fine and just refitting the lights to complete the job. Didn't even need to drill any holes Thumbs Up 2005 Td5 90 XS
Steve
Post #377406 8th Dec 2014 9:14pm
Terryt
williamthedog wrote:
Test fitted a foxwing eco,ready for the better weather
How is it mate ,got a 90 and torn between this and the tufftek 90 one.
Thanks in advance
Terry
Post #377409 8th Dec 2014 9:17pm
Kent_keith
England 2005 Defender 90 Td5 CSW Zambezi Silver
couplands wrote:
I got this one off ebay, probably why the fuse burnt out...!
http://www.ebay.co.uk/itm/161266923711?_tr...EBIDX%3AIT
Simon
http://www.paddockspares.com/boomslang-per...-loom.html
Quite a price differance between the two though? 2005 TD5 90 CSW XS
Post #377436 8th Dec 2014 10:28pm
Kent_keith
I'll follow that thank you Thumbs Up 2005 TD5 90 CSW XS
Post #377438 8th Dec 2014 10:31pm
Lou Sparts
Simon
Did it arrive in a blue box per chance Whistle 2005 Td5 90 XS
Steve
Post #377440 8th Dec 2014 10:35pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
^^^ from what I can tell from the pictures, all these kits seem to be the same (apart from the price). I have a Bluesea fuse panel, so will connect the power to that rather than the inline fuse holders in the kit.
For the price, I couldn't buy the cable and connectors, so can't complain.
Simon
Post #377445 8th Dec 2014 10:44pm
munch90
Simon
one reason I fused each side individually so I didnt lose both headlights ( made my own loom )
Post #377447 8th Dec 2014 10:49pm
Kent_keith
Simon
I agree they do look the same, well done spotting that Very Happy 2005 TD5 90 CSW XS
Post #377450 8th Dec 2014 10:55pm
Kent_keith
munch90 wrote:
Simon
What current capacity fuses did you use for each side please Very Happy 2005 TD5 90 CSW XS
Post #377452 8th Dec 2014 10:59pm
munch90
Playing with thermostats , 2nd experimental one
Post #377454 8th Dec 2014 11:01pm
munch90
Kent_keith wrote:
munch90 wrote:
Simon
think I put 20amp ones in , but really you could go bit lower , but std fusing is 10a dip beam for each side 10a high beam for each side so 4 fuses in all
trouble when you relay your running both dips beams togather and both high beams together on the one fuse with the loom you buy not really the way to do it
best way would be 2 looms and cut one side off , , but works out expensive way to do it !!
Post #377458 8th Dec 2014 11:13pm
My 3rd Defendoor arrived today, must find a way of securing it so it doesn't fly off in transit or go walked too easy before fitting it this time.
Post #377551 9th Dec 2014 2:20pm
Venomator
Don't forget to mark it with SMARTWATER then Steve... Whistle
At least the police will be able to trace the owner if it does fly off in transit... Rolling with laughter
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #377561 9th Dec 2014 2:34pm
redhandluke
United Kingdom 2003 Defender 90 Td5 SW Fuji White
Just had a new Twisted 18 inch rim delivered for a spare Thumbs Up Off tomorrow to have a new tyre fitted, bound to be cheap Rolling Eyes
Steve
Post #377647 9th Dec 2014 9:04pm
shaggydog
Milesone!
I did see 158000 but was on the motorway so didn't want to risk the photo.
However when I stopped for fuel the 13 year old in me couldn't resist the photo.
Neheheheheheh Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #377679 9th Dec 2014 10:37pm
