Home > Puma (Tdci) > Engine, Gearbox & Transfer Box Oil Change
Page 4 of 14 <123 45 ... 121314>
Cheshire110
Changed all the above + diffs oils today, your post was very helpful thanks!
Saved me a lot of time but sadly not the scuffed knuckles Laughing Cheers, David
Post #336069 5th Jun 2014 10:50pm
Schw8te
Germany 2013 Defender 90 Puma 2.2 SW Santorini Black
Thank you for this post! I changed the oil in the gearboxes and diffs. With this post a pleasure Smile
I filled the Motul Gear Competition in the Transfer Box - wow, what a difference! Smooth and easy.
Det locker bleiben
Post #336586 8th Jun 2014 11:00am
timbar
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Just stole half an hour to do my first engine oil change. Took about half an hour.
Then took about an hour to tidy up the oil dumped by the side of the road when I missed the drip pan Rolling Eyes
Things I learned: this'd be a lot easier with the landy up on ramps, and get something down on the ground first as your aim will be off. 2009 110 XS Station Wagon
Post #341952 30th Jun 2014 10:48pm
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
Does one replace the entire sump engine oil plug after an oil change or only the washer? Wheer would one typically pick this part up? Landrover?
Post #371299 12th Nov 2014 6:13pm
Rickydodah
The Plug is readily available from LR or most factors for about 3GBP. There is a moulded in rubber sealing washer as apposed to a copper washer type seal. Thumbs Up
Post #371313 12th Nov 2014 7:07pm
AlanH
Australia
I didn't bother getting a new plug but wrapped a couple of turns of thread tape around the old one. Works well with no drips.
AlanH.
Post #371369 13th Nov 2014 12:13am
Marius
What's the torque on the Diff plugs?
Post #392720 26th Jan 2015 4:19pm
ozy013
Australia 2010 Defender 110 Puma 2.4 SW Rimini Red
" Fill the front axle assembly with the correct amount of the specified oil.
Install and tighten the drain plug to 60 Nm (44 lb.ft). Install and tighten the filler plug to 60 Nm (44 lb.ft)."
Taken from workshop manual. Thumbs Up
Ian.
Post #392958 27th Jan 2015 11:53am
Marius
Are the diffs suppose to overflow when filled. I filled what I thought was 1.6l but it was not overflowing? Now I'm worried I underfilled...
Post #402282 26th Feb 2015 5:45am
MartinK
The diff filler is also a "level plug" - so the oil should be at the level of the filler hole. Usually I gill till it's just starting to overflow, and then pit the filler/level plug back in Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #402285 26th Feb 2015 7:56am
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
AlanH.
Hi,
on my old Range Rover, I did never change the copper washer seal and no problem ! (20 years and 500.000km, change oil every 5.000km )
on the defender, I will change it when necessary
Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #402288 26th Feb 2015 8:25am
Marius
I just did the transfer box oil. As per instruction I attempted to fill it to the filler plug level. I must have put in about 3.2 liters and it still didn't reach it...... My old Oil measured about 2.4 liters as per the said amount. Should I drain some out? Is the additional oil a problem?
Post #402455 26th Feb 2015 5:55pm
Marius
Oh dear...... Seems i didn't use the right fill plug. There seems to be a hex bolt higher up. I used that one to fill.
Now that was a dammmmnn rookie mistake....... What's that top bolt there for?
I'm hoping that I can open the proper filling plug and the oil should drain out until the right level.
Post #402463 26th Feb 2015 6:34pm
Bravemeister
United Kingdom 2010 Defender 90 Puma 2.4 HT Tamar Blue
I know this may of been asked before but i cant seem to find anything on the subject matter...
There seemed to be a leak coming from the filler plug on my gearbox.. I have since changed the fluids but while i was taking the filler plug out oil started to come out... I refilled but accidentally put a bit much in and filled to the fill plug.. The leak is still there Sad
I'm not 100% sure if the leak is the gearbox weeping oil or if its the seals on the prop that have gone and flinging oil everywhere and up the side of the gearbox.. will have another look tonight and maybe try and siphon a bit of oil out of the gearbox.
With 2.2 litres in the gearbox whats the distance from the filler plug to the level of oil inside..?
Dont really want to have to drain as i had to run a tap through the drain plug hole as some swarf got stuck in the threads when i did it the first time.....
Regards
Post #419688 28th Apr 2015 10:41am
DaveGL
2007 Defender 90 Puma 2.4 XS CSW Cairns Blue
Hi Guys
Just a paranoid check if you don't mind.
I just ordered a Mahle filter kit from advanced factors and some oil from opie oils.
I just want to make sure I definately got all the correct oils - I believe so from reading through this thread:
I have a 57 2.4Tdci 90:
Engine Fuchs 5w30 Titan supersyn F eco-dt - 7litres
Rear Diff Castrol universal 75w90w - 1.7litres
Front Diff Castrol universal 75w90w - 1.7litres
Gearbox Castrol universal 75w90w - 2.2L
All sound ok?
Just to avoid doubt, a pic of the oil!
Thanks
Post #438245 16th Jul 2015 12:46pm
