Home > Td5 > Strange clunk noise possibly in fuel tank
EWS
United Kingdom 2006 Defender 90 Td5 HT Alveston Red
'06 TD5 90---
We have an annoying dull clunk, coming from the rear of the truck. The local indy has checked all the suspension bushes and all seems okay. The clunk appears/sounds like it is coming from inside the fuel tank !!!!!!, you cannot force the clunk to sound of by throwing the the truck about (swinging it from side to side), its just random.
This is the second time this noise has put in an appearance, seems to happen after the tank is filled to max. I have just cut an inspection panel in the floor to access the pump, as were both sure its in the tank !!!.
Any thoughts any one ?????
Post #367169 25th Oct 2014 9:42pm
EWS
Well the clunk is still apparent,just moved the truck around on the drive, dropped of the drive(one inch drop onto the highway) and there it was, ,same when I came back on, this was a tick over ,just moving the truck around.(forward/reverse), even checked the mudflaps to see if they were loose!!!!!!,checked for loose cables !!!.
Still a mystery, will see what happens and then pull the the intank pump.
Post #367309 26th Oct 2014 7:09pm
excossack
A frame ball joint? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #367313 26th Oct 2014 7:22pm
EWS
Indy checked this as that was first thought, and crowbared it, with no apparent play, but I think I may get it replaced just to eliminate it.
Thanks for your reply
Post #367316 26th Oct 2014 7:30pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Do you have a rear anti roll bar ? Anti roll bar bushes and drop links are a common source of knocks/clunks on most cars 2005 Td5 90 XS
Steve
Post #367319 26th Oct 2014 7:47pm
EWS
Yes ,have anti roll bars front and rear, all bushes checked, levered or removed(split bushes) to visually check for wear..
Post #367320 26th Oct 2014 7:54pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I know this sounds daft but have you been underneath and given the exhaust a good waggle?
Other than that the rear A frame joint would be my guess, you don't need a crowbar on it see if it's worn, with the vehicle on the ground get someone to rock the wheels at 3 and 9 o'clock as if you are checking wheel bearing play, this will show play in the a-frame, also with the handbrake applied rock vehicle back and forth while laying under neath and you should see any movement present and this will also show play in the link arms too.
Yours isn't that old though, is the fuel tank loose somewhere? Can you move it from underneath with your hands?
Post #367330 26th Oct 2014 8:19pm
EWS
Exhaust secure and no contact with chassis or tank, tank is also secure. Think we will go down the elimination route, as looking through old receipts this evening, the A frame joint has not been replaced. Shocks and bushes replace a few months ago ( Bilsteins) .
Thanks for your thoughts.
Edward
Post #367361 26th Oct 2014 9:13pm
ibexman
Rear radius arm front bushes can clunk
Post #367366 26th Oct 2014 9:33pm
EWS
All the rear suspension bushes were checked and appeared to be okay,truck was on the lift all appeared to be okay, mechanic,owner /sole employee , who we have used for years, also could hear the clunk on a test drive( L/Rs are his business)
Thanks for your idea
Post #367375 26th Oct 2014 9:57pm
Lambley
I had a similar clunk a while back that I couldnt trace, it was at the very back and sounded like from underneath, I checked everything like you have, shocks, bushes etc, it turned out to be the bolts holding the latch on the rear door had worked loose, so I removed the door card, put 4 new nylock nuts on and it stopped straight away, it might be something simple.
Post #367393 26th Oct 2014 11:18pm
EWS
Hi Lambley.
Think you might have put me on the track. Always checked the door hinges for play when fully open, and no play. Door all most closed play really noticeable. I have packed out the lower door edge nearest the latch side with a cleaning cloth, so see what happens .(spare on rear door!!!!!)
Many thanks.
Edward
Post #367580 27th Oct 2014 8:10pm
Lambley
Ok, make sure you check the latch that's attached to the back door, the brass coloured part, mine was loose, it's held to the door with 4 nuts.
My spare is on a swing away carrier, it might be worth removing your spare and going for a drive without it.
Best of luck
Post #367651 27th Oct 2014 11:05pm
LandieG
I had similar, change of ball joint sorted, despite no apparent slack on the lifts - it apparently is under less tension on the flat than when up on the lift…? That's what I got told anyway, and as its sorted I'm inclined to believe it!!
Post #400993 21st Feb 2015 10:13pm
keith
Half shaft ?
Post #401013 21st Feb 2015 11:44pm
