![]() | Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
How hard were the rear windows to fit and where did you get them from?
The sliders and middle row were from masai. The sliders needed one corner of the appature filing out as the factory windows had less of a curve on one corner for some reason
So would recommend them both or save up and get Landyglass?
Are they decent quality? |
If you don't mind the work I would recommend them as the quality is good and the tint is not too dark, but have everything ready to do the job before you start or its a pita
Couple of bits turned up yesterday so I just need some dry weather now
![]() ![]() Click image to enlarge Last edited by mk1collector on 11th Sep 2017 1:12am. Edited 1 time in total |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
Fun times crawling on your back
![]() Let me know your verdict on the hydrate 80. 2002 110 td5 |
Yes, not looking forward to crawling round underneath
![]() ![]() I've already fitted the cps which seems too have sorted a slight hunting on idle I had, but I've only been for a short drive so,don't know if it's just a coincidence. The old cps did look rough though and didn't have the spacer! Ray |
Won some new genuine washer jets on ebay the other day, so I picked up some washer tube and a t peice from halfords over the weekend. I just need a bit of dry weather now to do the two washer mod and I'll hopefully have clear windows this winter
![]() ![]() Ray |
Beat you to the washer mod
![]() The hole is an oval, I used 2 tap washers to cover the hole and seal it. |
Didn't photo it
http://www.defender2.net/forum/post363091.html#363091 But can be seen in this photo, dead easy, just need a T piece about 2 foot of extra tube and some 1" rubber tap washers and a rubber grommet to fill old hole. ![]() |
Looks like it's a trip to b and q tomorrow for some washers then
Did that last week
