Page 739 of 1393 <123 ... 738739740 ... 139113921393>
Welcome to the spotlight club. Laughing
Post #360500 27th Sep 2014 2:14pm
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Not egzackly on my landy but for my landy, me and son replaced the hub seals, wheel bearings, brake caliper's and disc's on our disco 300tdi rear axle we recently bought ready for swapping over soon, oh and we gave it a lick of paint aswell, so all we need to do now is buy the A frame ball joint, propshaft flang kit, make and fit some new brake pipes and fit it sometime next month Very Happy Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #360521 27th Sep 2014 4:29pm
Venomator
Inigo wrote:
Finally (as in 3 years later) managed to fit my spotlights (as it needed A bar, which needed winch bumper and winch, etc).
So they ended up being rather expensive spots after all that... Whistle
Really do like the look of those though, well balanced with the headlights... Bow down
What make/type would they be?... Mr. Green
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #360532 27th Sep 2014 5:38pm
Alicat
Stopped on the hard shoulder of the M6 to untangle the rear mudflap from the tyre. By the time I realised what was happening a big chunk of mudflap had been eaten. Emergency repair carried out using zip ties.
Post #360537 27th Sep 2014 5:48pm
Towing a caravan?
Post #360538 27th Sep 2014 5:53pm
Alicat
Yes, I believe it is a common problem. Never had a problem before.
Post #360541 27th Sep 2014 5:55pm
Yeah it's pretty standard. It once drove a friend mad, smelt burning rubber, stopped, looked....couldn't see anything..repeat etc !!
Though I towed a t@b off-road caravan without any issues Question
Post #360543 27th Sep 2014 6:03pm
VeeTee
Netherlands
Greeni, what happens then when towing a caravan? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #360546 27th Sep 2014 6:06pm
Depends on the caravan shape and speed, but on a 90 the airflow sucks the mud flaps up into the tyres and it burns a notch into the flap!
Post #360552 27th Sep 2014 6:16pm
Alicat
For some reason the aerodynamics of towing a caravan causes the rear NS mud flap on a 90 to flip forward on yo the wheel. The wheel then eats the mud flap whilst the exhaust melts it!
Post #360553 27th Sep 2014 6:17pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
Lightforce Striker 170s. I believe I bought them from Brendan/Leeds, but it was so long ago I can't remember.
They nicely fill out the main beam so that I can see further into the distance when driving on the back lanes through the woods. Probably not strictly necessary, but I bought them before upgrading main headlamps to Wipac Crystals and going for the 110% bulbs.
Just need to stop the relay buzzing now. I have both spots through one 40A amp relay and I'm not sure its man enough. Sometimes sticks on. I have found a claimed 70A relay via ebay. Anyone know of any reputable double output relays rated to more than 40 Amps, that will fit a standard mini relay socket?
Post #360555 27th Sep 2014 6:33pm
A 40A relay is more than adequate for two 100w spots.
I'd change it to a quality manufactured one. (Quality varies)
My current one is from VWP and that's been on about three years now and is going great.
If it's sticking it's most likely on its way out / corroded.
Post #360571 27th Sep 2014 7:40pm
JWL
There only a few quid from a decent auto electric factors or you can go up a bit and get ones with fuses in. I have 6 x 100w spots on mine and run them as pairs through 40 amp relays and never had a problem for the past 7 years they've been on various motors.
Post #360577 27th Sep 2014 7:58pm
Never seen the point in the Relays with fuses in as they need to be fused as near the battery as possible anyway.
Depends if that's where you want to locate the relays or not.
In my case not, I have an in-line fuse near the battery and relay under bonnet.
Post #360594 27th Sep 2014 8:39pm
kipperthedog
Fitted tweeters to the top of the dash......
Pleased with the result. Cheap (Got them out of a scrap MG ZR), tidy and a big improvement in sound.
Post #360863 28th Sep 2014 8:01pm
