![]() | Home > My Defender > g-macks 110 300 tdi thread |
Landy-Novice Member Since: 23 Jun 2013 Location: wiltshire Posts: 118 ![]() ![]() |
didn't realize its a new head. thought it was a recon. certainly shiny!
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
yuup! brand new
![]() my youtube channel |
cured a few squeaks today. first was to change serp belt tension-er bearing. it was pretty goosed when i took it off!, and also found source of another annoying squeak which turned out to be oil cooler pipe rubbing against bonnet stay bracket!! My 109 thread
sick of spending money trying to find booming issue, i decided it was time to spend on a mod! so cheap as chips DRL bumper conversion.
used ring auro lights off ebay £30 some surrounds to bolt to bumper £15 total outlay £47!! the rings were second hand but never installed!, still in sealed packaging ![]() the surrounds made it easier to finish, as i was using a grinder to cut bumper i had no way off getting a good cut! they come on when engine starts, dim 50% when lights are on and stay on 20 seconds after engine switched off. ( coming home lights) everything off ![]() Click image to enlarge engine running ![]() Click image to enlarge side lights /dim-dip on ![]() Click image to enlarge main beam ![]() Click image to enlarge My 109 thread my youtube channel |
Finally got round to fitting a rear recovery point! My 109 thread
my youtube channel Last edited by g-mack on 25th Nov 2014 4:44pm. Edited 2 times in total |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5088 ![]() ![]() ![]() |
Bumper looks good with DLR's
![]() You have side light out ![]() |
yea, debating whether to replace bulb, replace both front side lights with rdx leds, or replace all 8 lamps with rdx led units!! My 109 thread
New led sides and rear lights
![]() Click image to enlarge Got some crystal headlights to fit too! My 109 thread my youtube channel |
WOW Led sidelights and tail lights are awesome!! super bright
sweepc Member Since: 19 Jun 2011 Location: uk Posts: 568 ![]() ![]() |
Are they the Wipac ones? I was impressed with mine just thought the indicators are a little white
Look good though
no they are rdx ones. not done indicators yet but they are on the list
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 ![]() ![]() ![]() |
Great bumper
I have led side lights and stop tail lights, much better ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Steve I was shocked at how much better rear ones are
![]() ![]() my youtube channel |
