Home > My Defender > g-macks 110 300 tdi thread
Page 14 of 25 <123 ... 131415 ... 232425>
Landy-Novice
didn't realize its a new head. thought it was a recon. certainly shiny! Mr. Green Thumbs Up
Post #358247 16th Sep 2014 6:43pm
g-mack
Post #358252 16th Sep 2014 7:07pm
g-mack
cured a few squeaks today. first was to change serp belt tension-er bearing. it was pretty goosed when i took it off!, and also found source of another annoying squeak which turned out to be oil cooler pipe rubbing against bonnet stay bracket!! My 109 thread
my youtube channel
Post #361252 30th Sep 2014 4:41pm
g-mack
sick of spending money trying to find booming issue, i decided it was time to spend on a mod! so cheap as chips DRL bumper conversion.
used ring auro lights off ebay £30 some surrounds to bolt to bumper £15
total outlay £47!!
the rings were second hand but never installed!, still in sealed packaging Thumbs Up
the surrounds made it easier to finish, as i was using a grinder to cut bumper i had no way off getting a good cut!
they come on when engine starts, dim 50% when lights are on and stay on 20 seconds after engine switched off. ( coming home lights)
everything off
engine running
side lights /dim-dip on
main beam
 My 109 thread
my youtube channel
Post #366408 22nd Oct 2014 12:05pm
g-mack
Finally got round to fitting a rear recovery point! My 109 thread
my youtube channel
Post #374155 25th Nov 2014 4:26pm
gilarion
Bumper looks good with DLR's Thumbs Up
You have side light out Wink
Post #374156 25th Nov 2014 4:29pm
g-mack
yea, debating whether to replace bulb, replace both front side lights with rdx leds, or replace all 8 lamps with rdx led units!! My 109 thread
my youtube channel
Post #374158 25th Nov 2014 4:37pm
gilarion
Best thing I ever did was to replace Brake, side and indictors with LED's. I bought the Wipac ones and an RDX relay, no more blown bulbs, and as they are fully waterproof no water seeping in to corrode the fitting. Plus very easy to replace as they are the same dimensions as the originals, although you may have to swap over the live and negative feed but that is no great problem.
Post #374159 25th Nov 2014 4:47pm
g-mack
New led sides and rear lights
Got some crystal headlights to fit too! My 109 thread
my youtube channel
Post #383041 29th Dec 2014 4:38pm
g-mack
WOW Led sidelights and tail lights are awesome!! super bright Shocked very very happy My 109 thread
my youtube channel
Post #383092 29th Dec 2014 6:22pm
sweepc
2013 Defender 90 Puma 2.2 XS CSW Santorini Black
Are they the Wipac ones? I was impressed with mine just thought the indicators are a little white
Post #383093 29th Dec 2014 6:25pm
sweepc
Look good though Thumbs Up
Post #383095 29th Dec 2014 6:26pm
g-mack
no they are rdx ones. not done indicators yet but they are on the list Thumbs Up My 109 thread
my youtube channel
Post #383112 29th Dec 2014 7:16pm
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
Great bumper
I have led side lights and stop tail lights, much better
Post #383137 29th Dec 2014 8:17pm
g-mack
Steve I was shocked at how much better rear ones are Thumbs Up gonna have to do indicators next Thumbs Up My 109 thread
my youtube channel
Post #383138 29th Dec 2014 8:21pm
