Home > Technical > Help please
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
Help please
How on earth do you get into a maxtel spotlight? The mounting screws are just holding the bracket to the casing, there is a small black screw which doesnt come all the way out and there are two small slots on the other edge. Im half way through a job!!! Thanks!
Post #350388 8th Aug 2014 6:20pm
Jonno1968
Main reason for asking is there is a white wire and a black wire...is it very safe to assume the black is the earth? Thats all i need to know.....i was to open them up and have a look......but it does beg the question....how do you change a bulb when needed!
Post #350389 8th Aug 2014 6:21pm
Jonno1968
Someone must know.....!!
Does anyone know the answer to the above....please!
Post #350438 8th Aug 2014 11:47pm
mikeh501
If it's just a bog std bulb then it won't matter
Post #350475 9th Aug 2014 8:12am
Jonno1968
Does if i cant get into the unit! Any idea on the white and black wire comeing put the back......they look fab but they aint wired ul yet cos i dont want to get it wrong and blow the bulb before they get to work! ....someone must know........
Post #350611 9th Aug 2014 7:09pm
mk1collector
Surely if it's a standard bulb, it won't matter which is earth and which is live.
Post #350626 9th Aug 2014 7:34pm
Jonno1968
Oh really? I do t understand electrics!! I thought i may end up having a permanent live to the casing? No?
Post #350628 9th Aug 2014 7:35pm
mk1collector
I'm no electrics expert but if it was earthed through the casing wouldn't only one wire be coming out? You might be best waiting for more electrical minds to add there thoughts.
Post #350637 9th Aug 2014 7:41pm
landy andy
The white will be the live the black will be the earth. You could do a continuity test of the two wires to the body to confirm if unsure. Can't help with getting into the light, but posting a photo would be a good idea.
Andy
Post #350699 10th Aug 2014 6:50am
mikeh501
Like I said, if it's just a bulb then it won't matter which way around. Try it on a battery.
Post #350713 10th Aug 2014 9:22am
munch90
yes I agree , only problem is if the bulb earth is not insulated from the body of the lamp
really only way is to check with a multimeter , check for continuity between wires and body of lamp
but they must come apart somehow for bulb change , if they are that hard to get apart or you have to damage them to get apart I wouldn't be fitting them
Post #350715 10th Aug 2014 9:27am
