|  | Home > Technical > Help please |
| Jonno1968 Member Since: 24 Oct 2013 Location: Leicestershire Posts: 245      | Main reason for asking is there is a white wire and a black wire...is it very safe to assume the black is the earth? Thats all i need to know.....i was to open them up and have a look......but it does beg the question....how do you change a bulb when needed! | ||
|  8th Aug 2014 5:21pm |
 Does anyone know the answer to the above....please! | ||
|  8th Aug 2014 10:47pm |
| mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142    | If it's just a bog std bulb then it won't matter | ||
|  9th Aug 2014 7:12am |
| Jonno1968 Member Since: 24 Oct 2013 Location: Leicestershire Posts: 245      | Does if i cant get into the unit! Any idea on the white and black wire comeing put the back......they look fab but they aint wired ul yet cos i dont want to get it wrong and blow the bulb before they get to work! ....someone must know........ | ||
|  9th Aug 2014 6:09pm |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772      | Surely if it's a standard bulb, it won't matter which is earth and which is live. | ||
|  9th Aug 2014 6:34pm |
| Jonno1968 Member Since: 24 Oct 2013 Location: Leicestershire Posts: 245      | Oh really? I do t understand electrics!! I thought i may end up having a permanent live to the casing? No? | ||
|  9th Aug 2014 6:35pm |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772      | I'm no electrics expert but if it was earthed through the casing wouldn't only one wire be coming out? You might be best waiting for more electrical minds to add there thoughts. | ||
|  9th Aug 2014 6:41pm |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059    | The white will be the live the black will be the earth. You could do a continuity test of the two wires to the body to confirm if unsure. Can't help with getting into the light, but posting a photo would be a good idea.
 Andy | ||
|  10th Aug 2014 5:50am |
| mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142    | Like I said, if it's just a bulb then it won't matter which way around. Try it on a battery. | ||
|  10th Aug 2014 8:22am |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558    |
 yes I agree , only problem is if the bulb earth is not insulated from the body of the lamp really only way is to check with a multimeter , check for continuity between wires and body of lamp but they must come apart somehow for bulb change , if they are that hard to get apart or you have to damage them to get apart I wouldn't be fitting them | ||
|  10th Aug 2014 8:27am |
| Posting Rules
