Home > Maintenance & Modifications > Installing a aux power socket in the rear
Page 7 of 11 <123 ... 678 91011>
LR90XS2011
Caterham wrote:
great bit of useful info. thanks Thumbs Up
just wondering if anyone knows where to get replacement trim / clips - trip to LR?
will be pulling the trim off to do this mod along with some other 'stuff' I'm doing in that area.
Broke my clips doing this K9F advised on replacements will see if I can find post DEFENDER 90 TDCI XS,
Post #345686 16th Jul 2014 10:10pm
timbar
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
munch90 wrote:
oh dear , don't worry we all done it at sometime , one of those 'oh bo!!ocks ' moments
glue a flat piece of plastic on the back over the hole then cut RIGHT size hole and when the socket is fitted doubt you would notice the mistake
you may find that recovering from your mistake and not just buying a new part will give you better satisfaction ! , when the job turns out ok
Thumbs Up for this approach Smile 2009 110 XS Station Wagon
Post #345735 17th Jul 2014 8:13am
timbar
Thumbs down for double posts. 2009 110 XS Station Wagon
Post #345736 17th Jul 2014 8:13am
Dale
United Kingdom 2001 Defender 110 Td5 Tomb Raider LE Bonatti Grey
Caterham wrote:
I need the memory of a goldfish as I believe they can remember things upto 3 seconds or so?
I measured the 12v outlet and found the right hole saw Re checked etc....picked up the arbour and then the hole saw.......
Picked up the wrong hole saw Big Cry now need new speaker surround......as I'm lining the drill up I'm thinking it's too big but thought stayed in brain and didn't transmit to finger - hence big hole.
You could use large plastic washers sandwiched each side of the panel, then the socket through the middle of them.
Post #345843 17th Jul 2014 3:35pm
Dale
Just fitted one to my 110 double cab. Thanks for the tip! Thumbs Up
Post #346491 20th Jul 2014 2:43pm
lohr500
Thanks for all the tips.
Purple & Black plug was behind the right hand side panel in the rear of my 2011MY XS 110 Station Wagon.
The hardest part was removing the trim panel because Mr Land Rover had bolted the 3rd seat row support right where the panel needs to hinge upwards Thumbs Up With a bit of flexing and sliding out sideways it finally gave in.
I took the advise from an earlier post and cut the plug off to reveal the two spade terminals which then go onto the spades on the 20 Amp aftermarket socket I purchased from CPC. The spade terminals have locking tags which give a more secure connection to the socket than just a push on connector. A bit of heat shrink over each terminal finishes the job off and makes it safer. The CPC 12v socket was approx. 29mm diameter and I marked out the hole size using the tightening ring nut which holds the socket in place. Drilled a series of small holes and then used a Stanley knife to cut out the rest.
Job done from start to finish in less than 20 minutes.
And it works Laughing
Post #371634 14th Nov 2014 4:25pm
PCA42
England 2008 Defender 110 Puma 2.4 DCPU Tonga Green
Went to do this small mod to my 110 DCPU to power work light, my small 12v tyre inflator etc and stuff like that.
I bought a socket that the connector would fit straight to the back of, however when I came to put the panel back in after fitting it I realised the socket was too long and was hitting the bodywork behind Sad So new solution need!
However, I found these 2 other connectors behind the panel, a multi plug and 2 spade terminals. What are these for? I have a 7 plug towing socket fitted to the vehicle. My guess for the two smaller plugs are to power a speaker in SW variants? (Outside marine speakers anyone Laughing )
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
2010 Discovery 4 GS TDV6
1972 Series III 88" 2.25P
Post #386355 8th Jan 2015 5:04pm
Multiplug contains the connections for the rear wiper and heated rear screen for hardtop variants. On DCs from 2007 to about 2010(?) the harness for these is present, and can be very useful for adding LED worklights etc.
I think that the spade connectors are for the right rear speaker on SW/USW models. Again, the earlier DCs had the wiring fitted.
Post #386364 8th Jan 2015 5:14pm
PCA42
Ahhh I see, blackwolf. So if I wanted to power a worklight etc, I'd just need to get a male connector of the same type and wire in to the relevant wires? Are there connectors to these wires behind the dash i.e. just a switch required? Pete
Post #386424 8th Jan 2015 7:17pm
I used the HRW feed for my worklights. Installed the switch (wiring and connector already there), plugged a standard relay into the HRW relay socket (wiring already there), then cut the two HRW wires at the rear connector and fitted suitable bullet connectors. Then connected my LED worklights to the bullets.
This gave worklights but only with ignition on (but with a warning light on the instrument panel to tell you the lights are on) so I later put a permanent live feed to the switch.
Post #386431 8th Jan 2015 7:41pm
PCA42
Oh right, excellent, thanks for the explaination! Thumbs Up Shame it doesn't come out on the other side, as I'd like to put a worklight on a Far Corners numberplate light bracket! Pete
Post #386462 8th Jan 2015 8:20pm
I added a pair of wires running to the n/s for the second light.
Post #386606 9th Jan 2015 12:01am
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Purple wire is there on my 2000 110 CSW. (BOY I LOVE THIS BOARD!!) Does anyone know what the orange plug is for?
Post #394661 1st Feb 2015 1:59am
DC101
United Kingdom 2005 Defender 110 Td5 CSW Zambezi Silver
Can anyone advise as to a complete loss of electrical power to my rear aux socket?
I may have missed the answer in this topic; is the positive fused elsewhere (2003 TD5 DC)?
I've also noticed that my fridge previously had struggled to run from the socket, except when engine was running (a Waeco CF). Is it possible that there is a noticeable voltage drop to the rear socket (I may be talking nonsense , as I'm no electrical expert, so please tell me!)
Thanks All,
Rob
Post #422428 10th May 2015 5:36pm
Dale
Fuse for the purple wire on my 110DC (2001) is under the drivers seat in the additional fusebox next to the ECU.
Post #426825 28th May 2015 9:31am
