Home > Technical > Horn sounds like it has a sock in it. |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2166 |
2nd Jul 2014 6:42pm |
Buccaneer Member Since: 11 May 2014 Location: London/Kabul Posts: 148 |
Anyone got anything sensible to add? The Rules:-
1 Buccaneer comes back alive. 2 Chicks dig scars. GB260 |
2nd Jul 2014 6:44pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19662 |
Check connections are secure.
2nd Jul 2014 6:48pm |
Will get that done tomorrow - had Trucklites fitted yesterday - (forgive terminal dumbness here) is the horn anywhere near the light fittings? The Rules:-
2nd Jul 2014 6:49pm |
No nastyness intended Buccaneer
2nd Jul 2014 6:55pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
Are horns still adjustable ? They used to have an adjuster screw in the middle with a lock nut.
Can't say I've looked at one lately but they may not have anymore. 2005 Td5 90 XS Steve |
2nd Jul 2014 7:41pm |
SimonDavies Member Since: 15 Mar 2012 Location: Swansea Posts: 244 |
If you are getting battery voltage at the horn, then the horn must be faulty. May have water ingress.
2nd Jul 2014 8:25pm |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 677 |
I know many people claim to be able to fix anything on a Land Rover with a hammer but try tapping it with a hammer, the diaphragm inside could be bunged up with crud and dust, worth a try before spending £'s
2nd Jul 2014 8:27pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1874 |
Did someone get the horn!
2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
2nd Jul 2014 8:29pm |
No the horn is still present as clearly indicated by the symptoms The Rules:-
1 Buccaneer comes back alive. 2 Chicks dig scars. GB260 Last edited by Buccaneer on 2nd Jul 2014 9:12pm. Edited 1 time in total |
2nd Jul 2014 8:56pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5429 |
The horn is behind the head light, so would check the connections first.
Andy |
2nd Jul 2014 9:12pm |
N/S or O/S? The Rules:-
2nd Jul 2014 9:24pm |
If it as taken in water, you will still hear it, but it will be a dull/muted sound.
2nd Jul 2014 10:13pm |
is it worth just leaving to see if it will dry out or is that not an option? The Rules:-
2nd Jul 2014 10:14pm |
