![]() | Home > Technical > Horn sounds like it has a sock in it. |
| SimonDavies Member Since: 15 Mar 2012 Location: Swansea Posts: 244
I've never really heard of one drying out. I dont think a new 12v horn will cost you too much.
But as mentioned, before you go purchasing new, make sure you have full battery voltage to the horn from the plug. |
| mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142
mine regularly gets filled with mud. a quick blast with the jet wash solves those issues
| mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 605
Take a broken horn as a reason to upgrade
Best |
| Buccaneer Member Since: 11 May 2014 Location: London/Kabul Posts: 148
Horn was
1 Buccaneer comes back alive. 2 Chicks dig scars. GB260 |
| WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935
So did the horn sound change before or after the Trucklites were installed. If after, seeing as the horns are behind headlights, then definitely check connections.
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
| All times are GMT |
