Home > Technical > Horn sounds like it has a sock in it.
Buccaneer
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
My horn sounds like someone has stuffed a sock in it - really muted and barely noticeable - any ideas? The Rules:-
1 Buccaneer comes back alive.
2 Chicks dig scars.
GB260
Post #342299 2nd Jul 2014 6:26pm
keith
Post #342308 2nd Jul 2014 6:42pm
Buccaneer
Anyone got anything sensible to add? The Rules:-
2 Chicks dig scars.
GB260
Post #342309 2nd Jul 2014 6:44pm
Check connections are secure. Thumbs Up
Post #342311 2nd Jul 2014 6:48pm
Buccaneer
Will get that done tomorrow - had Trucklites fitted yesterday - (forgive terminal dumbness here) is the horn anywhere near the light fittings? The Rules:-
2 Chicks dig scars.
GB260
Post #342312 2nd Jul 2014 6:49pm
keith
No nastyness intended Buccaneer
Post #342313 2nd Jul 2014 6:55pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Are horns still adjustable ? They used to have an adjuster screw in the middle with a lock nut.
Can't say I've looked at one lately but they may not have anymore. 2005 Td5 90 XS
Steve
Post #342321 2nd Jul 2014 7:41pm
SimonDavies
Wales 2010 Defender 90 Puma 2.4 HT Zambezi Silver
If you are getting battery voltage at the horn, then the horn must be faulty. May have water ingress.
Post #342328 2nd Jul 2014 8:25pm
rustandoil
I know many people claim to be able to fix anything on a Land Rover with a hammer Very Happy but try tapping it with a hammer, the diaphragm inside could be bunged up with crud and dust, worth a try before spending £'s
Post #342329 2nd Jul 2014 8:27pm
bear100
Did someone get the horn!
Rolling with laughter Rolling with laughter 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #342330 2nd Jul 2014 8:29pm
Buccaneer
No the horn is still present as clearly indicated by the symptoms The Rules:-
2 Chicks dig scars.
GB260
Post #342338 2nd Jul 2014 8:56pm
landy andy
The horn is behind the head light, so would check the connections first. Thumbs Up
Andy
Post #342340 2nd Jul 2014 9:12pm
Buccaneer
N/S or O/S? The Rules:-
2 Chicks dig scars.
GB260
Post #342344 2nd Jul 2014 9:24pm
SimonDavies
If it as taken in water, you will still hear it, but it will be a dull/muted sound.
Post #342358 2nd Jul 2014 10:13pm
Buccaneer
is it worth just leaving to see if it will dry out or is that not an option? The Rules:-
2 Chicks dig scars.
GB260
Post #342360 2nd Jul 2014 10:14pm
