Home > Maintenance & Modifications > Load space trims fit?
DavidS
United Kingdom 2011 Defender 110 Puma 2.4 USW Stornoway Grey
Sorry if this has been covered before, but I have had my Defender back at the dealers to remedy a fault with the clutch (common problem).
While in, I asked if they could look at the trim in the luggage area, as it moves, and seems to be missing clips? It is a 110 utility XS.
The dealer has told me that they are all like that and some worse than others..... are they taking the mick, or do all of your plastic trims not hold on to anything, rattle and generally not sit where they should?
The girl was lovely and even said that it adds to 'the charm of the Defender'...... 2 LandRovers, and counting!
Post #334585 30th May 2014 3:31pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
I don't know the trim specifically, but sounds like a typical dealer excuse to not bother doing the work.
Post #334589 30th May 2014 3:46pm
GUM97
If it is missing clips, it is missing clips at the end of the day! They should put it right definitely! I suspect you've been fobbed off! Rolling Eyes An engine to TDi for!
Post #334600 30th May 2014 4:21pm
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
I picture showing which item you are referring to might be a good idea. 1998 110 300Tdi White Hard Top
Post #334686 30th May 2014 9:33pm
Pickles
Yes, we might have common ground. I found a bolt/washer after a bad rattle, still don't know where it came from, so I'd be interested in what you are encouintering, which trims, & what clips/fittings etc are missing?
Pickles.
Post #334706 30th May 2014 10:39pm
DavidS
Hi guys thanks for the replies. I will post pics when I get a minute.
The trim is the dark grey plastic. For example either side of the rear door is a trim which would surround the window in a station wagon. Mine flaps? 2 LandRovers, and counting!
Post #334750 31st May 2014 9:44am
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Trim should move and certainly not flap. Push them to get it sorted
Post #334751 31st May 2014 10:03am
Caterham
sorry to wonder off topic here Off Topic
just wondering what the clutch prob is you refer to ?
Post #334753 31st May 2014 10:34am
DavidS
Hi caterham, I had a rattle on the clutch, replacement supplied and different car now. Again I was led to believe that 'they are all like that Sir'... 2 LandRovers, and counting!
Post #334938 1st Jun 2014 9:23am
