![]() | Home > Maintenance & Modifications > Load space trims fit? |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 ![]() ![]() |
I don't know the trim specifically, but sounds like a typical dealer excuse to not bother doing the work.
If it is missing clips, it is missing clips at the end of the day! They should put it right definitely! I suspect you've been fobbed off!
![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 ![]() ![]() ![]() |
I picture showing which item you are referring to might be a good idea. 1998 110 300Tdi White Hard Top
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3798 ![]() ![]() ![]() |
Yes, we might have common ground. I found a bolt/washer after a bad rattle, still don't know where it came from, so I'd be interested in what you are encouintering, which trims, & what clips/fittings etc are missing?
Pickles. |
DavidS Member Since: 14 Apr 2014 Location: North East Posts: 55 ![]() ![]() ![]() |
Hi guys thanks for the replies. I will post pics when I get a minute.
The trim is the dark grey plastic. For example either side of the rear door is a trim which would surround the window in a station wagon. Mine flaps? 2 LandRovers, and counting! |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1320 ![]() ![]() ![]() |
Trim should move and certainly not flap. Push them to get it sorted
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
sorry to wonder off topic here
![]() just wondering what the clutch prob is you refer to ? |
Hi caterham, I had a rattle on the clutch, replacement supplied and different car now. Again I was led to believe that 'they are all like that Sir'... 2 LandRovers, and counting!
