![]() | Home > Maintenance & Modifications > Mud Shields |
trouble is with defender built tolerances nothing can be mass produced that's a tight fit !
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 ![]() ![]() ![]() |
So after a few hours I have given up fitting these to the rear of MY2009 Puma. So annoyed as the instructions make it seem simple but with the rear seat belt supports I could not fit them without undoing a lot of sub work. Please tell me it is just me and there is a way around fitting them http://www.gwynlewis4x4.co.uk/product/land...epped-tub/ Frustrated Steve |
Sadly mine seems to collect mud so have been seeking ways to cut down the hours of cleaning
doublea Member Since: 12 Jul 2011 Location: Aberdeenshire Posts: 495 ![]() ![]() ![]() |
On my 110 utility, theses were a breeze to fit. Although it has the stepped rear tub, it doesn't have the brace for the seat belt mounts. I reckon they're essential to preserve the rear crossmember as they protect all the way down to the lower edge, which is right in the line of fire for blasting by the rear wheels.
I also fitted them to the 90SW, it was necessary to remove the brace on each side. It wasn't too bad as the vehicle was brand new, there are two awkward nuts at the top rear, removed from underneath with a socket extension and universal joint, two bolts with captive nuts accessed via the seatbelt end inside and the two bolts going through the rear crossmember.It shouldn't be necessary to remove a rear step bumper so long as the nut is removed from the ends of the bolts going through the rear crossmember; the whole brace should move forward and off the ends but the fuel filler will restrict movement after a point. I got the brace powder coated and wax treated whilst it was removed. As for value for money, it depends how you value your own time. Rather than buying a third set, I recently made my own. They're not as good as the gywn Lewis ones but they'll do the job. If I need another set, I'll be forking out! Current Steeds: 2015 110 UW in Grasmere Green 2003 BMW F650 the Hack 2000 Elise 1992 Ducati 888 (no longer in bits, yahoo) 1990 TDR 250 (in bits again) 1988 TDR 250 (no longer in bits) and for sale |
driver9 Member Since: 15 Oct 2012 Location: Suffolk Posts: 111 ![]() ![]() ![]() |
I have been pleased with my mud shields even though the ones that protect the cross member were a bit of a pain to fit. As stated before proving you can remove the nuts holding the seat belt anchor to the cross member you should be able to fit them. Have you highlighted the problem you are having to Gwyn Lewis? They might be able to point you in the right direction.
I extended the front of the inner wheel arch liners on my 90 so the bumper does not fill up with crud. |
Hi Driver9,
Thanks for the info. Yea, I emailed them this morning and am sure they will come back with a solution I was just a little annoyed this morning when I write this note ![]() Thanks, Steve |
There's a way you can fit them without bolting anything through the tub.
You need some of what GL call speed screws (they have other names but they're fairly easy to get hold of if you know what you're looking for, ebay have them or https://www.beal.org.uk/hardware-fasteners...tml?page=2 ) then just mount the angle brackets the other way round to one of the top hat tub bracing brackets. ![]() Click image to enlarge |
thor44 Member Since: 18 Sep 2015 Location: Ahrntal, Südtirol Posts: 128 ![]() ![]() |
I recently installed the full set on my 90. Fitting the front mud shields was really a piece of cake. The rear ones were a little bit more cumbersome to install, mostly because of the awkward positions of some screws.
Nevertheless I think they are a valuable addition to any Defender, especially after I had to remove at least 2kg of mud and dirt from the rear crossmember and behind the original mud shields which obviously should have the purpose of protecting the back lights and wiring from mud in the first place. ![]() Click image to enlarge . _____ .|_____\___ [|_/-\__/-\_|} ...(O)....(O)........ MY14 2.2 Defender 90 SW |
Yes, the amount of mud I could out of mine was quite alarming.
And all the stuff attached on to the front of the bulkhead too! I ended up with a huge heap on the floor. |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1247 ![]() ![]() |
I have just fitted a front set and a set in front of the rear wheels on my 110 csw. My truck is now 24 years old and suffering from all the road dirt and salt thrown forward attacking the cross rail supporting the tub and the side frames. Yes they are expensive but they will do the job. You can still get behind them to clean out the area if necessary and the rears will come out simply by removing two screws.
Having repaired the damage I am confident this will help prevent more damage long term. I always washed out the mud traps but it still corroded and had trapped mud inside when I finally took it all apart. If I had a new or nearly new 110 I would fit them as soon as I could. |
