Home > Maintenance & Modifications > Mud Shields
General Grabber
Mud Shields
Afternoon all,
Just seen these on the Gwyn Lewis site.
http://www.ebay.co.uk/itm/Land-Rover-Defen...2a3d0a3a59
I have their front outrigger shields fitted and they are a very useful bit of kit, and am considering getting these rear shields too.
Has anyone fitted these to a Puma yet?
Cheers.
Post #332547 21st May 2014 4:05pm
SailingTom
I asked them a month or so ago as they have made them for 110's a while longer. Well done as hadnt seen they were listing them yet, Ill be ordering a pair Thumbs Up Defender puma dormobile camper
Post #332550 21st May 2014 4:35pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Good spot - Going to have to get a set of these! They just need to bring out ones for in front of the rear wheel and that is everything protected!
Post #332551 21st May 2014 4:39pm
General Grabber
Cheers, Scott, Tom,
Yes, liners for the front of the rear wheel arch would be perfect.
Seeing as we are on the subject, does anyone know why Defenders do not come with a pre-installed, fully formed wheel arch liner like virtually every other vehicle?
Could it be due to the restriction it would impose on tyre/wheel combinations?
Or is it just cost?
Post #332553 21st May 2014 4:44pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Wont they just hinder cleaning and become a mud trap in themselves?
Post #332554 21st May 2014 4:47pm
Leenorthants
Shocked
That's a helluva mark up for 4 bits of laser cut plastic and nuts, I reckon after all costs and machine time is taken into consideration, that's £5 total!
Post #332571 21st May 2014 5:59pm
My thoughts exactly. Hence why I'll use a piece of old tank mudflap and a stanley knife at some point.
Post #332575 21st May 2014 6:20pm
borderterrier
what they said
Post #332580 21st May 2014 6:39pm
Romadog
Fit Entreq guards to the front of the arches.
I have the front wheel arch kit from Gwyn which are great and am contemplating his rear set for square rear arches.
Post #332587 21st May 2014 7:11pm
Cupboard
we've got some old bits of conveyor belt on ours.
Post #332709 22nd May 2014 8:52am
landy andy
I will getting a set. Also the removable rear mud flap kit that he does.
Andy
Post #332723 22nd May 2014 9:44am
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
I have the new removable rear mud flaps and there're a really good product although they take a while to fit.
Post #332733 22nd May 2014 10:02am
driver9
Today I fitted a set of rear mud shields to my 90SW. I agree they are a little expensive but if they are as effective as the front ones it will be money well spent.
I applied Waxoy to the body and rear cross member before they were fitted just in case mud gets behind them like it had with those originally fitted by Land Rover.
Post #334247 28th May 2014 9:23pm
General Grabber
So, I ordered these mud shields and as with previous orders, they were delivered in record time by Gwyn Lewis.
So far so good.
However, I do have a word of warning, which is not made clear by Gwyn Lewis.
As I have now found out after a very frustrating couple of hours at the weekend, it is impossible to fit these to any vehicle that has a tubular bumper without first removing the whole bumper and towbar assembly. Which is clearly not a 5 minute job.
On my 90 CSW there is a bracket under each side of the rear tub that supports for the rear seatbelts. This is explained in the comprehensive instructions GL provide with the mud shields. These need to be removed before the mud shield can be installed. However the lower of the two bolts that hold on these supports is held captive behind the bumper.
There is no way to remove the bolt as far as I can see without removing the bumper and towbar. And that is something that I am just not prepared to do, just to fit a couple of bits of laser-cut plastic.
So if you have a tubular bumper fitted, it might be worth checking before you spend £47 that you can get your brackets off and your mud shields in place.
Consequently I now have a pair of brand new but ever so slightly scuffed mud shields that are of no use.
Post #334303 29th May 2014 7:16am
adamatdraycott
United Kingdom 2014 Defender 90 Puma 2.2 SW Corris Grey
The front ones work well, as they don't create a mud trap... These look as though they might, and it won't be easy to clean.
I'd be wary of fitting these due to lack of air circulation around the area. I'd also be wary of plugging cross member holes as people have mentioned previously.
Post #334426 29th May 2014 7:04pm
