Home > In Car Electronics > DAB radios |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5085 |
It is only ‘Sport Extra’ that is not available on long wave, but radio 4 broadcasts the same programme on long wave opt out, on the same frequency 198, so it amounts to the same!
I do not mean to dismiss DAB radio, it could be fantastic, but until the channel is broadcast using a better frequency that has the same signal strength as the existing radio frequencies and has equal national coverage it will remain inferior to the existing FM. I have several DAB radios and I can assure you that while the signal is very clean the quality of broadcast in no way matches FM stereo. Last edited by gilarion on 19th May 2014 8:14pm. Edited 2 times in total |
19th May 2014 8:05pm |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
Ok...
Cheers Simon |
19th May 2014 8:07pm |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 |
I think DAB is great for my purposes
Have been running it exclusively for knocking on 5 years now. I used to listen to Planet Rock - now Team Rock radio (no adverts!), and despite the odd half second breakup, I've had perfect coverage over 99% of the areas I've driven in. Wouldn't dream of going back to analogue |
19th May 2014 8:47pm |
Dale Member Since: 14 Jul 2014 Location: Bristol Posts: 79 |
Got a Pure Highway 260 Dab radio with stick on windscreen type DAB aerial. Never had any reception problems with it. Mounted aerial top centre of windscreen behind rear view mirror so it's nice and neat and out the way. The radio itself also supports Bluetooth so can stream music from my phone, and can also using it for hands free calls. Radio comes with a small mic, which again I have tucked away at top of windscreen out of the way. Cheap unit from Halfrauds, but very pleased with the results.
17th Jul 2014 12:04am |
alastaid Member Since: 03 Dec 2013 Location: York Posts: 78 |
I am huge DAB fan, and bought a Blaupunkt unit off Dab on Wheels 5 or 6 years ago, couldn't recommend them highly enough as they do have the try and return policy. I first tried the FM --> DAB converter thingy that used the existing FM aerial but it didn't work for me. I returned it with no problems and bought the bee sting type DAB aerial.
I have recently transferred all of this to my 90, and its brilliant, I have replaced the DAB aerial for the FM, and slotted in the Blaupunkt into the dash and it works brilliantly. Will take a couple of pics and post. Cheers Alastair |
18th Jul 2014 10:08am |
