![]() | Home > Technical > Footwell a tad damp! Bear with me! |
| ChrisJ Member Since: 12 Nov 2013 Location: Warwickshire Posts: 231
The seals can be changed yes, available from most reputable spares shops although I'd opt for genuine ones myself.
Do you plan on using the vents? I suppose silicon or similar will cure the problem but if it was me I'd swap the seals. |
| jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
As above, new seals and keep adding seals till it stops leaking,only real Defenders have flaps at the front
| 110MGD Member Since: 17 Oct 2013 Location: Wear Valley Posts: 153
I've got a slight leak round the back door! Gave up trying to fix! I lauds accept it, mind it's only minor 2001 Td5 CSW (weekend and snow mobile) Plenty of lights, M/T tyres EGR delete, roofrack, swing away wheel carrier, snorkel.
2016 E220 CDI Night Edition Estate 2014 VW UP! 2x D3 and 1x D4 GONE |
| simon119 Member Since: 05 Apr 2012 Location: SG11, Herts Posts: 40
Replace the seals with the older style rubber ones not the newer foam ones. I couldn't get mine to seal even with genuine foam ones, changed to the latter rubber ones and hey presto!!
If i can find the part numbers i'll post them up #MUC4299 x 2 HTH |
| Buz Member Since: 24 Jan 2014 Location: Forest of Dean Posts: 238
Thanks Simon, i'll get some ordered
| kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1324
Simon - any idea if same part number applies to 59 plate Puma? I have same issue with small leak from vent seal
.. delete double post
| Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2677
i went out to my 14 plate hire car this morning, i thought a bottle of water had fallen over somewhere in the car... couldn't believe it.
Don't have vents on Puma's dude,lol. Non puma
Puma Pov.spec,ftw. 2006, 110,TD5. |
| Mountain_man Member Since: 09 Dec 2011 Location: Right side of Offas Dyke Posts: 756
Have you tried leaving the bear at home. Perhaps he is a bit incontinent?
| VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Yeah i'm aware they don't open. But there appears to be some sort of felt lining around there that is damp. If its a completely sealed area as your pic suggests, then must be coming form around the windscreen |
| taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663
In the Defender Waterproofing manual, there's a "fix" for this.
One part is the fix an extra layer of closed cell foam to the vent flap, the other is the drill a hole (possibly 16mm, I cant remember the figure) further down on the flap lever section so that the 'closed' position pulls the vent tighter in place when closed. It reduces the open gap slightly, but not by much ... I'll see if I can find it! |
Also fitting Series vent seals was part of it to I think!
| All times are GMT |
