Home > Technical > Footwell a tad damp! Bear with me!
Buz
United Kingdom 1987 Defender 90 200 Tdi HT Barolo Black
Looks like I have a bit of a leak in the passenger footwell, yep, they all do that sir!!!
I think it is coming through the vents that are under the screen. I have a TD5 dash to go back in so don’t think i’ll be using the vents. Can the seals be changed on them? Is it worth it or shall I just silicone them up and hopefully cure the issue?
I’ve added some pics for you guys to ponder and see if you agree this is where its probably coming in?
Post #325700 23rd Apr 2014 8:19pm
ChrisJ
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
The seals can be changed yes, available from most reputable spares shops although I'd opt for genuine ones myself.
Do you plan on using the vents? I suppose silicon or similar will cure the problem but if it was me I'd swap the seals.
Post #325708 23rd Apr 2014 8:50pm
jimbob7
As above, new seals and keep adding seals till it stops leaking,only real Defenders have flaps at the front Whistle,so shunt be sealed up. Does anybody know if you can adjust the hinges (by bending Rolling Eyes ),as they are spot welded on I don't know how much force it would take before they snapped off Shocked ? Pov.spec,ftw. 2006, 110,TD5.
Post #325736 23rd Apr 2014 9:58pm
110MGD
2001 Defender 90 Td5 CSW Epsom Green
I've got a slight leak round the back door! Gave up trying to fix! I lauds accept it, mind it's only minor 2001 Td5 CSW (weekend and snow mobile) Plenty of lights, M/T tyres EGR delete, roofrack, swing away wheel carrier, snorkel.
2016 E220 CDI Night Edition Estate
2014 VW UP!
2x D3 and 1x D4 GONE
Post #325745 23rd Apr 2014 10:43pm
simon119
United Kingdom 2000 Defender 90 Td5 HT Rutland Red
Replace the seals with the older style rubber ones not the newer foam ones. I couldn't get mine to seal even with genuine foam ones, changed to the latter rubber ones and hey presto!!
If i can find the part numbers i'll post them up
#MUC4299 x 2
HTH
Post #325771 24th Apr 2014 7:23am
Buz
Thanks Simon, i'll get some ordered Thumbs Up
Post #325890 24th Apr 2014 7:25pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Simon - any idea if same part number applies to 59 plate Puma? I have same issue with small leak from vent seal
Post #326211 26th Apr 2014 12:21pm
kmac
.. delete double post
Post #326212 26th Apr 2014 12:21pm
Likeomg
i went out to my 14 plate hire car this morning, i thought a bottle of water had fallen over somewhere in the car... couldn't believe it.
Post #326213 26th Apr 2014 12:28pm
jimbob7
Don't have vents on Puma's dude,lol.
Non puma
Puma
Post #326224 26th Apr 2014 2:05pm
Mountain_man
Wales
Have you tried leaving the bear at home. Perhaps he is a bit incontinent? Razz
Post #326239 26th Apr 2014 3:47pm
VeeTee
Netherlands
^^^ Rolling with laughter Rolling with laughter Very Happy Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #326254 26th Apr 2014 4:46pm
kmac
Yeah i'm aware they don't open. But there appears to be some sort of felt lining around there that is damp.
If its a completely sealed area as your pic suggests, then must be coming form around the windscreen
Post #326308 26th Apr 2014 9:25pm
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
In the Defender Waterproofing manual, there's a "fix" for this.
One part is the fix an extra layer of closed cell foam to the vent flap, the other is the drill a hole (possibly 16mm, I cant remember the figure) further down on the flap lever section so that the 'closed' position pulls the vent tighter in place when closed. It reduces the open gap slightly, but not by much ...
I'll see if I can find it!
Post #327198 30th Apr 2014 10:38am
taazzukcb
Also fitting Series vent seals was part of it to I think!
Post #327199 30th Apr 2014 10:47am
