![]() | Home > My Defender > DarthFender TD5 110 |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
Now there's a good idea
when i did mine in a 2003 110, scarey moment when you start cutting the wheel arch .. great idea Mk1
This weekend I've mostly been re-trimming, sound deadening and insulating the roof.
Mouldly, dirty headliner ![]() Click image to enlarge Cut re-trim fabric to size ![]() Fold in half and spray on contact adhesive ![]() Push and mould to contours ![]() Insulate Light backing before re-fitting to save fuses ![]() Fold over edges and glue and tape up ![]() Looking good so far, two more to go ![]() Silent Coat the roof (cheap Dynamat) ![]() ![]() Managed to pick a Military "NATO TUM" 110 HazMat kit ![]() The inside of the kit was then cut and used over the top of the sound deadening material ![]() ![]() Start to refit the trim ![]() ![]() ![]() Very happy ![]() |
Quick 30mins addition. Thanks to Myers for the extra light I now have a light in the middle of the 110 (why LR have never put one there is a mystery)
No light ![]() Masked up and carefully cut a hole, fished the wires that I'd left there for this job ![]() Installed to a Factory finish ![]() ![]() ![]() |
Tonight's little job was to add some soundproofing to the bonnet.
Quickly measured the sound in the cab at idle. 63.3db was about the average ![]() Then got to work on the kitchen table ![]() ![]() First step was Silent Coat (cheap Dynamat) to kill the vibrations and add a bit of mass ![]() Then Silent Coat Hoodliner ![]() Tape it all up nice and neat ![]() Put it back on the car and measure in exactly the same way ![]() Dropped 3.5db at idle, I'll know better tomorrow when I drive it if it feels quieter |
You could also stick 1cm thick felt to the underside of your bonnet,I used cable tie's as well for a bit more security.
http://www.frost.co.uk/sound-deadening-felt-sheets.html Pov.spec,ftw. 2006, 110,TD5. |
Bit tight for space now.
Touches the coolant bottle lid ![]() |
Next major project is the transmission tunnel as I reckon that's where most of the noise comes from.
Well, drove it today and it's made a difference, not massive but 1 step closer to being nicer on long runs.
I think the transmission tunnel will make the biggest difference. |
Stage2 started
I put sound deadening and closed cell foam across the whole floor bulkhead and transmission tunnel and then put the original trims and mats etc back (these were a bit tight) and it made quite a big difference. You've also given me another job
