![]() | Home > Puma (Tdci) > wont even break when its supposed to? |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
not going to bore you with all the different problems I've had etc.....
but now the damn thing won't 'break' when its supposed to? ![]() after struggling to fit an egr bland and nearly giving up I've managed to fit an undersized plate by wedging it in place. the plate has no hole in it and as such I was fully expecting it to bring a fault code up (MIL).... But oh.....engine seems at long last to be working fine but no MIL? .....Oh and LR have told me all is fine ![]() |
How many threads in the last 48 hours have you started and or mentioned EGRs???
1. http://www.defender2.net/forum/topic27439.html 2. http://www.defender2.net/forum/topic27430.html 3. http://www.defender2.net/forum/topic27400.html Another thread just out of the 48 hour zone too. ![]() Tried to resist the temptation but failed..... Told you....... ![]() If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
![]() Sorry....just.....well you've probably guessed already. ??? No hole in the blank and no MIL??? Drives nice tho? |
Are you 100% sure the bodge job you've done by wedging your undersize plate in place is not either bypassing or leaking? Either way you should have either a P1102 or P1103 code and an associated MIL light. If you go through life with your head in the sand....all people will see is an ar5e!!
99% sure.
![]() Click image to enlarge Not the best photo...(just took it) .... hopefully you can just make out the plate that is 90deg round from where it should be (if it was the right size) ... So if no MIL does anyone know what might be broken? Putting the blank in has / appears to have improved things greatly.......so at the moment I'm of the opinion I need a new EGR.....any other thoughts? |
I thought you had recently taken it to a dealer to sort assess and sort the turbo out? Steve.
Yep. New turbo fitted.
But due to my suspicious nature / still not convinced everything was at it should be I thought I'd have a go at fitting the egr blank to see if that would sort the intermittent knocking noise I've long suspected to be related to the egr...... I'm now sure the egr isn't 100% because now not only is it running MUCH better early results suggest it’s running consistently too. ![]() I'm not amazed at how many problems I've had?? And if the egr is the culprit how on earth is it LR haven't sorted it before now??? |
![]() ![]() Something else to worry about. ![]() No they're not too tight so I don't expect any issues on that front (well I wouldn't on any other car ![]() |
caterham , how many miles has your puma done
36k miles
What you thinking? ![]() |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
I'm certain the blank goes manifold side ? 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
you can get blanks to go either side , I would prefer to blank before egr if poss to keep the crap out of egr
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17935 ![]() ![]() ![]() |
Perhaps you need a new bulb in the MIL!
Indeed also the bit in the picture that is hanging out looks to me to be one of the slots that the bolts slide into ? Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
