![]() | Home > Puma (Tdci) > wont even break when its supposed to? |
Experience probably....The best tool in the box!
![]() Treat every day as if it is your last....one day you will be right!! |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
Couldn't agree more
Beginning to think the only tool round here is me
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17933 ![]() ![]() ![]() |
Not a chance on a 2011, unless someone found a 4 year old engine lying around the factory! |
if you got a noise from the egr valve yes but then its knackered .im talking causing engine noise |
The egr......I suspect is ok. while stationery if I rev the engine to about 2k I believe I can hear the egr open then close and I get chukka chukka when I turn the engine off
The knocking I refer to is occasional and as I've always thought sounds like the knocking I'd expect to hear from wrong fueling..... Def went in for replacement breather on fuel tank which apparently ended with tank removal....car ran a treat for a day or so after....overtaking cars and all sorts which for anyone who knows me means something was out of the ordinary (ordinarily good in this instance) When I did service / fuel filter..again immediate improvement but short lived. Mostly happens first thing in the morning but has happened a few other times..can pull off and seems like the engine takes a few seconds to catch up.....bit like the clutch is a great big rubber band and it's unwinding??? But the annoying part is the knocking.........sometimes low revs in top gear and no hesitation, just smooth like you'd expect from a modern diesel...........other times in what 'I' would expect to be as close as to make no difference the same circumstances and the fueling seems to be all wrong???? I've wasted plenty of money already so it may come as no surprise I'm considering 'wasting more '..... How much to replace the engine loom? ![]() Last edited by Caterham on 19th Mar 2014 1:21pm. Edited 1 time in total |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
I will be massively interested to know if Lorryman can sort this out for Caterham, try imagining how frustrating it would be owning his Land Rover DEFENDER 90 TDCI XS,
Blackwolf....i'm sure u r iright ...not a chance but with my paranoia I suspect perhaps has been rotting in a field for a long time just waiting for some mug with big ears to turn up ....
Frustrating is nothing compared to the pyschoatric costs. |
Did you change the VCV? The symptoms sound lot like a faulty VCV. Perhaps you've found another faulty one.
sorry thought I'd replied to this already....
yes replaced the vcv......can't recall now whether it made any difference or not......seem to think it didn't (just made my wallet thinner) ![]() |
![]() ![]() just had a call from the body shop to confirm def paint work is ready............. and they've taken it to service as the engine malfunction light is on. ![]() ![]() |
Cakey Member Since: 19 Feb 2013 Location: Cheshire Posts: 468 ![]() ![]() ![]() |
I hope you removed the blanking plate
![]() There goes your warranty You seriously need to get rid , and buy a lotus or Morgan ![]() |
erm....the blank is still there hence the mil light.
if I get shot of this it'll be back to a Caterham. within reason the only couple of vehicles that interest me at the moment are the def and Caterham. |
One consolation the dealer may not know a lot about defenders .
Love ur threads by the way, cheer up my day ![]() If u get a caterham let me know when u join that forum. Now that will be entertaining . If they are like the tvr or lotus I had Popcorn popcorn beer ![]() |
