Home > Puma (Tdci) > wont even break when its supposed to?
Page 1 of 5 12345>
Caterham
not going to bore you with all the different problems I've had etc.....
but now the damn thing won't 'break' when its supposed to? Evil or Very Mad
after struggling to fit an egr bland and nearly giving up I've managed to fit an undersized plate by wedging it in place. the plate has no hole in it and as such I was fully expecting it to bring a fault code up (MIL)....
But oh.....engine seems at long last to be working fine but no MIL?
.....Oh and LR have told me all is fine Rolling with laughter
Post #315288 11th Mar 2014 6:27pm
K9F
How many threads in the last 48 hours have you started and or mentioned EGRs???
1. http://www.defender2.net/forum/topic27439.html
2. http://www.defender2.net/forum/topic27430.html
3. http://www.defender2.net/forum/topic27400.html
Another thread just out of the 48 hour zone too. Whistle
Tried to resist the temptation but failed.....
Told you....... Rolling with laughter
K9F wrote:
Ideally this is what you need not a single blank with no hole......Caterham knowing your luck the whole thing will end in tears. Big Cry Big Cry
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #315314 11th Mar 2014 9:02pm
Caterham
Embarassed
Sorry....just.....well you've probably guessed already.
??? No hole in the blank and no MIL???
Drives nice tho?
Post #315317 11th Mar 2014 9:13pm
K9F
Are you 100% sure the bodge job you've done by wedging your undersize plate in place is not either bypassing or leaking? Either way you should have either a P1102 or P1103 code and an associated MIL light. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #315319 11th Mar 2014 9:18pm
Caterham
99% sure.
Not the best photo...(just took it) .... hopefully you can just make out the plate that is 90deg round from where it should be (if it was the right size) ...
So if no MIL does anyone know what might be broken?
Putting the blank in has / appears to have improved things greatly.......so at the moment I'm of the opinion I need a new EGR.....any other thoughts?
Post #315327 11th Mar 2014 9:37pm
Happyoldgit
I thought you had recently taken it to a dealer to sort assess and sort the turbo out? Steve.
http://forums.lr4x4.com
Post #315346 11th Mar 2014 10:12pm
Caterham
Yep. New turbo fitted.
But due to my suspicious nature / still not convinced everything was at it should be I thought I'd have a go at fitting the egr blank to see if that would sort the intermittent knocking noise I've long suspected to be related to the egr...... I'm now sure the egr isn't 100% because now not only is it running MUCH better early results suggest it’s running consistently too. Thumbs Up
I'm not amazed at how many problems I've had??
And if the egr is the culprit how on earth is it LR haven't sorted it before now???
Post #315353 11th Mar 2014 10:24pm
munch90
looking at the photo hope the two bolts aren't that tight , there is no support under each side where the bolts are , be careful you haven't bend the mating flanges
I can't think of any egr problem on transit 2.4 that hasn't given a fault code, but will ask a mate who knows more about them
Post #315356 11th Mar 2014 10:28pm
Caterham
Shocked Shocked
Something else to worry about. Big Cry
No they're not too tight so I don't expect any issues on that front (well I wouldn't on any other car Laughing )
Post #315358 11th Mar 2014 10:34pm
munch90
caterham , how many miles has your puma done
Post #315360 11th Mar 2014 10:43pm
Caterham
36k miles
What you thinking? Very Happy
Post #315361 11th Mar 2014 10:45pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
I'm certain the blank goes manifold side ? 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #315362 11th Mar 2014 10:46pm
munch90
you can get blanks to go either side , I would prefer to blank before egr if poss to keep the crap out of egr
Post #315365 11th Mar 2014 10:49pm
Perhaps you need a new bulb in the MIL!
Post #315367 11th Mar 2014 10:50pm
big steve
Indeed also the bit in the picture that is hanging out looks to me to be one of the slots that the bolts slide into ?
Steve 2015 2.2 tdci hardtop xs
Post #315368 11th Mar 2014 10:52pm
Page 1 of 5 12345>
