Home > Maintenance & Modifications > Galvanizing
Page 3 of 3 <123
db950 - I thought that May be the case, I don't currently have a tap and die kit but they aren't expensive to foam one off job.
Cuthbert - I know the callings you mean, normally black or grey plastic. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #310119 21st Feb 2014 12:55am
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
I would just buy the individual tap sizes you need for the job, you get a lot of stuff you never use in a full set! 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #310156 21st Feb 2014 8:58am
Laurie
Aldi and Lidl do very cheap metric sets occasionally.
Alternatively, take an HTS bolt and file a section at the end similar to those on a tap. Zinc is a soft metal, it should do the job.
Post #310231 21st Feb 2014 1:05pm
Does anyone know if Wedge can take the items like rear step as is and do the whole stripping and then Galving in one go to come back to refit?
I don't mind painting myself once galved but I don't really want to strip it all myself nor go various places to get it done, I don't mind drilling box section and removing plastic caps etc though in advance.
Not only that if I stripped it at home rust will set in before it'd even get sent. Later in the year when a bit of spare £ is available I shall have to contact them..
Needs to be done this year for certain, got the dreaded powder coating peel. ____\We|Will|Win/___
Post #312764 2nd Mar 2014 12:49am
SailingTom
Do you mean stripping the whole thing tread and all or just the coating off it?
If its just the paint/ powdercoating give them a call. Mine will but it costs a bit extra (a NAS bumper will be about £20 probably to have blasted before galvanizing so I wouldnt loose any sleep over the cost Smile )
Its worth doing though, im going to do the same once I get my next one with sidesteps and bits, Ill be taking new ones to have done straight away (powdercoating doesn't like where I live much apparently)
When you say about it rusting if left outside once stripped. It will but at such a slow rate if stored off the ground it will only be surface rust, so no issue for galvanizing or long term strength.
Cheers Tom Thumbs Up Defender puma dormobile camper
Post #312793 2nd Mar 2014 8:09am
When I say stripped, obviously I'd remove any plastic caps and chequer plate and the like, I just meant the powder coat stripping basically.
I will have to do this this year I think, just get the pennies together now. Laughing ____\We|Will|Win/___
Post #314296 7th Mar 2014 5:02pm
Cuthbert
Before dipping a mild steel component in the hot zinc bath - it needs to be very clean (no flaking, scale, rust, remains of paint/plastic etc) - usually shot-blasted and pickled/acid bath.
Post #314467 8th Mar 2014 1:36pm
Cuthbert
Have been updating myself on powder coating technology with a visit to a supplier of powder coated components to the automotive sector. Met with the tech guru and toured the process from start to finish.
Oh the joys of quality and pricing issues - and the longevity of the finished coated components.
So what did I learn - all about the short cuts and where some folk apparently cut corners. What did I already know - unless the preparation is really thorough and quality powders are applied correctly - that lovely looking surface will soon just peel and flake off.
Post #370960 11th Nov 2014 12:38am
Page 3 of 3 <123
