Home > Maintenance & Modifications > Converting Hard Top 90 to Pickup???
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I've seen a local 90 that's low miles and in good shape but I'd like a pickup rather than hard top. I've heard of pickups being converted to hard tops but not the other way round, is it as easy as it looks and what problems am I likely to encounter? It's a 1990 that I'm looking at.
Post #302997 28th Jan 2014 10:46pm
GUM97
Can be done! Pretty simple, remove roof, sides and rear door, and then fit tailgate and truck cab roof. Thumbs Up If it's a SW then it's harder as there's no bulkhead, but if it's a plain HT then is simple. An engine to TDi for!
Post #302998 28th Jan 2014 10:48pm
Lambley
Cheers, yes its a hard top not a SW. So, all I need is a tailgate, truck cab roof, rear section with windows and a roof liner?
Do I have to change the log book for any reason?
Post #303000 28th Jan 2014 10:53pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
The tailgate will need some lugs welding on to the rear cross member to hinge on,Unless you are going to hinge it from the body to open sideways. 2005 Td5 90 XS
Steve
Post #303003 28th Jan 2014 11:00pm
Weston18
England 1999 Defender 110 300 Tdi DCPU Tonga Green
Also a cab mounted spare wheel mount if its going to be proper.
Post #303050 29th Jan 2014 8:24am
roel
Before you are going to build a pick-up. Drive one. As I liked the looks off my sheep carrier. (I could still smell them) But I found there is not enough space to sit nicely behind the steering wheel. I am just 1.8 m so not very tall.
I changed it to a hard top. Roel
2003 90 Td5 (2009-now)
Post #303053 29th Jan 2014 9:18am
SailingTom
Hi Lamby
Shame as I've just changed my 2011 truck cab to soft top, but just sold all the bits.
Like Roel says make sure you drive one for a bit first as although I loved the look of mine as a cab it didn't work for me at all. I miss the heat from the heater, but that's it!
Stating the obvious somewhat, you cant leave anything in the back without the risk of it going walkies (I live in a nice area aswell!) and by the time all your stuffs in the cab, there's no room at all, plus with the full headlining your seat has to be further forward so leg room is an issue even for shorty's like me Thumbs Up Defender puma dormobile camper
Post #303064 29th Jan 2014 10:26am
Lambley
Thanks for the above replies
I've recently sold my old pick-up and I miss it, hence looking for another one. I've got a nice, clean, tidy low miles hard top and could just use that, but I'm a bit anal about it and would rather have something I'm not too worried about, the old pick up I have was ideal, it only cost me £1k plus about the same again in parts to make it road worthy. I just want a hack to go fishing in, bum around the village etc.
I do like the looks of a pick-up but take on board about what you're saying about the space and practicality element, if I end up buying this ex-fire station 90 h/t it might end up staying a hard top for a while, it's either buy another landy that's slightly different or buy a car that I' not worried about.
Post #303077 29th Jan 2014 11:31am
Weston18
Ever thought about a king cab? more space inside and if done correctly look alright!
Post #303082 29th Jan 2014 12:17pm
landys1
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Santorini Black
Lambley, well I've just done it the other way round, pickup to SW (sons 90, he needed the extra seats for his mates!). As other posts say, hard top to pickup is an easy job to do.
If you decide to go down this route, and are after some bits, I've got a pickup cab (good nick with headlining), tailgate, spare wheel carrier etc., everything you would need to do the job, from the conversion I've just done. If you are interested, let me know - couple of pictures below, also one of pickup with tonneau cover fitted, keeps everything dry! (also for sale). All the bits are now off the landy and dry stored.
Cheers, Andrew
 1959 Series 2 Ragtop
1989 SWB Stationwagon
1998 300Tdi Hard Top and 2012 2.2 Puma Hardtop (at work)
2011 Puma 90 2.4 XS
Post #303158 29th Jan 2014 6:06pm
Lambley
Cheers Andrew, would you hang on to them and give me first dibs, pm me a price if you can too.
The ex Fire Service 90 I was looking at has just been sold, no surprise really as it'd only done 35k miles, good for a H reg vehicle!
Your truck looks perfect for what I'm after too, lovely looking thing, if I can fine a blue one that matches - your on!
Post #303174 29th Jan 2014 6:56pm
landys1
Yeah, no worries, the bits aren't going anywhere soon, i was going to sell them come spring time - just let me know when/ if you're in a position to want them - guess it all depends on you finding a decent truck - Good luck with the search! Thumbs Up 1959 Series 2 Ragtop
2011 Puma 90 2.4 XS
Post #303179 29th Jan 2014 7:08pm
Lambley
Do you mean something like a Nissan Navara?
Post #303191 29th Jan 2014 7:46pm
GUM97
Something like this is a "King Cab"...
http://www.defender-landrover.co.uk/2013/1...-tomb.html
Foley's sell a conversion kit...
http://foleysv.com/parts/cab-extension-kit An engine to TDi for!
Post #303204 29th Jan 2014 8:19pm
Lambley
Blimey, never seen one of those, didn't know there was such a thing!
Post #303225 29th Jan 2014 9:29pm
