![]() | Home > Puma (Tdci) > Clutch again! |
What a flurry of information in a short time.
![]() MK I think you've made someone happy..... ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Harryb450 Member Since: 11 Dec 2011 Location: over yonder Posts: 283 ![]() ![]() ![]() |
VERY happy!
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2505 ![]() ![]() ![]() |
Canīt remember very well, but wasnīt hard to get it out. Now, for the whole thing is just like the old ones. Heavy as hell and a bit PITA to disconnect the hyd line running beside the Gbox close to the entry of the bellhousing (on a LHD). It is kind of tricky to remove the exhaust with the cat as it does not fit between the engine and chassis. You need to turn it and move up and down untill you find a unique position to take it down. This last part can be frustrating and worth lots of swearing against LR
![]() ............................................................. Earth first. Other planets later |
Harry if you can get a jack under the engine and apply pressure with the jack this will give you the extra 5mm you need to get the catalytic convertor out a lot easier.
With the Griffin you've got I'm surprised the cat's still there? Maybe time to bin the cat anyway perhaps? Good luck. ![]() Treat every day as if it is your last....one day you will be right!! |
no cat under there, he's long gone!
well..... all bits ordered, just need the postie to deliver them now
can you throw a picture of the findings? Puma 110" SW
I sure can, wont be till next weekend though
I guess this is not the first swap? Puma 110" SW
its the second one its had, 1st under warranty
what's the best method of removing the spigot bearing? NO ROAD..........EXCEPT FOR LANDROVER
There is a (LR) special tool for it. Otherwise you need to use the old "bread or grease" method (google it). Puma 110" SW
