Home > Puma (Tdci) > Clutch again!
Page 2 of 3 <123>
K9F
What a flurry of information in a short time. Bow down
MK I think you've made someone happy..... Thumbs Up Bow down If you go through life with your head in the sand....all people will see is an ar5e!!
Post #302278 26th Jan 2014 1:33pm
Harryb450
United Kingdom 2011 Defender 110 Puma 2.4 USW Santorini Black
VERY happy! Thumbs Up Thumbs Up Bow down Bow down Very Happy Very Happy NO ROAD..........EXCEPT FOR LANDROVER
Post #302279 26th Jan 2014 1:36pm
Harryb450
does the transfer stick unclip like the gear stick? can the box be slid back like with the old ones? any tips/tricks? NO ROAD..........EXCEPT FOR LANDROVER
Post #302288 26th Jan 2014 1:56pm
MK
Canīt remember very well, but wasnīt hard to get it out. Now, for the whole thing is just like the old ones. Heavy as hell and a bit PITA to disconnect the hyd line running beside the Gbox close to the entry of the bellhousing (on a LHD). It is kind of tricky to remove the exhaust with the cat as it does not fit between the engine and chassis. You need to turn it and move up and down untill you find a unique position to take it down. This last part can be frustrating and worth lots of swearing against LR Twisted Evil Puma 110" SW
Post #302298 26th Jan 2014 3:05pm
Harryb450
Thumbs Up thank you Thumbs Up NO ROAD..........EXCEPT FOR LANDROVER
Post #302300 26th Jan 2014 3:15pm
K9F
Harry if you can get a jack under the engine and apply pressure with the jack this will give you the extra 5mm you need to get the catalytic convertor out a lot easier.
With the Griffin you've got I'm surprised the cat's still there? Maybe time to bin the cat anyway perhaps?
Good luck. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #302306 26th Jan 2014 3:33pm
Harryb450
no cat under there, he's long gone! Rolling with laughter NO ROAD..........EXCEPT FOR LANDROVER
Post #302307 26th Jan 2014 3:35pm
K9F
Cool Mine too. Meeeooowww....No more!!!!! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #302308 26th Jan 2014 3:37pm
Harryb450
well..... all bits ordered, just need the postie to deliver them now Very Happy Thumbs Up NO ROAD..........EXCEPT FOR LANDROVER
Post #302414 26th Jan 2014 9:28pm
MK
can you throw a picture of the findings? Puma 110" SW
Post #302427 26th Jan 2014 9:53pm
Harryb450
I sure can, wont be till next weekend though Thumbs Up NO ROAD..........EXCEPT FOR LANDROVER
Post #302430 26th Jan 2014 9:56pm
MK
I guess this is not the first swap? Puma 110" SW
Post #302443 26th Jan 2014 10:28pm
Harryb450
its the second one its had, 1st under warranty Thumbs Up it didn't rattle till about a week or 10 days since, then the other night it just went, so I'm wondering if 1 of the springs has come out and is wedged which is stopping the clutch disengaging. no doubt i'll find out Rolling with laughter NO ROAD..........EXCEPT FOR LANDROVER
Post #302461 26th Jan 2014 11:10pm
Harryb450
what's the best method of removing the spigot bearing? NO ROAD..........EXCEPT FOR LANDROVER
Post #303118 29th Jan 2014 3:20pm
MK
There is a (LR) special tool for it. Otherwise you need to use the old "bread or grease" method (google it). Puma 110" SW
Post #303129 29th Jan 2014 4:04pm
Page 2 of 3 <123>
