Home > Td5 > Water Ingress through roof
charliebaja
United Kingdom 2002 Defender 110 Td5 CSW Zermatt Silver
Hi Guys,
I am sure there a lot of water ingress topics on here, but non that i can find about the top A-pillar corner to roof!
I have water coming in from above the A-Pillar but i cant work out exactly were from. I have pulled all the old Dum Dumb tape and re sealed it with silicon, but its still pouring in. Can anyone suggest anything or give advise?
Post #301173 22nd Jan 2014 12:59pm
mk1collector
I just resealed mine up as it was coming in at the top of the a post. If you look at the roof line at the front and follow it down to the gutter I found a hole where the two meet that let a lot of water in.
Post #301181 22nd Jan 2014 1:21pm
TooTall
United Kingdom 2004 Defender 90 Td5 HT Tonga Green
The beauty of this stuff is that it finds the leak for you! Laughing
http://www.captaintolley.com/ "Ease your worries, Clear-up your woes,
Go into your garage & put stuff into rows."
Post #301191 22nd Jan 2014 1:33pm
K9F
Start at the beginning and work your way through...... Thumbs Up
http://www.scribd.com/doc/17833628/water-ingress-manual If you go through life with your head in the sand....all people will see is an ar5e!!
Post #301200 22nd Jan 2014 2:08pm
charliebaja
Thanks for the help here guys, I have bought some Capt Tolley's Creaking crack cure and hope that it finds and seals the water issue. I will update all when finished as to the results.
Post #301224 22nd Jan 2014 3:48pm
VeeTee
Netherlands
I also had water ingress at the corner of the roof and A pillar. Took me couple of years to find it! There was a tiny pinhole in roof corner at the rear end. The water in the outer gutter entered there and travelled along the inner gutter forward to the A pillar. First time braking or cornering after a rain shower the water would land on your knee! Shocked Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #301246 22nd Jan 2014 5:09pm
Gareth
Capt Tolleys Creeping crack cure is good. I used to seal the alpine windows and side windows on my 90. Its still good after a year. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #301261 22nd Jan 2014 6:04pm
landefender
France 2002 Defender 110 Td5 CSW Barolo Black
water ingress
where can I get hold of this magical Captain Tolley creeping crack stuff
Thanks in advance for the rply
Walter
Post #303962 1st Feb 2014 12:53am
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Post #303970 1st Feb 2014 1:55am
landefender
water ingress / Captain Trolley
Thanks for your swift reply. I only hope that they are shipping to France. Can't wait to try it and will make my experience known
thanks again
Walter
Post #303989 1st Feb 2014 9:48am
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Didn't they print an updated water ingress manual?
Post #303990 1st Feb 2014 9:49am
landefender
water ingress
I have the downloadable pdf manual, but I feel that I have to look further than what the manual gives me. So, I am banking on the Captain Tolley methode. Thanks for your post anyway
Walter
Post #304046 1st Feb 2014 12:26pm
charliebaja
the Captain Tolley is very good, but i now see that the water is coming in from further down the car, perhaps the top window in the middle. I might have to pull it out to check. I cant see any other holes anywhere in the back.
Post #304886 3rd Feb 2014 11:39pm
borderterrier
The window in the middle, you referring to the alpine windows? Capt Tolley will sort them out, just make sure it's been dry or a few days and there is no water in the gap. If there is if has the effect of watering down the sealant as it is water based.
Post #304900 4th Feb 2014 12:00am
