![]() | Home > Td5 > Water Ingress through roof |
charliebaja Member Since: 05 Aug 2013 Location: Surrey Posts: 211 ![]() ![]() ![]() |
Hi Guys,
I am sure there a lot of water ingress topics on here, but non that i can find about the top A-pillar corner to roof! I have water coming in from above the A-Pillar but i cant work out exactly were from. I have pulled all the old Dum Dumb tape and re sealed it with silicon, but its still pouring in. Can anyone suggest anything or give advise? |
TooTall Member Since: 10 Jul 2012 Location: Fens Posts: 504 ![]() ![]() ![]() |
The beauty of this stuff is that it finds the leak for you!
![]() http://www.captaintolley.com/ "Ease your worries, Clear-up your woes, Go into your garage & put stuff into rows." |
Start at the beginning and work your way through......
![]() http://www.scribd.com/doc/17833628/water-ingress-manual If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Thanks for the help here guys, I have bought some Capt Tolley's Creaking crack cure and hope that it finds and seals the water issue. I will update all when finished as to the results.
I also had water ingress at the corner of the roof and A pillar. Took me couple of years to find it! There was a tiny pinhole in roof corner at the rear end. The water in the outer gutter entered there and travelled along the inner gutter forward to the A pillar. First time braking or cornering after a rain shower the water would land on your knee!
![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1138 ![]() ![]() |
Capt Tolleys Creeping crack cure is good. I used to seal the alpine windows and side windows on my 90. Its still good after a year. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy |
landefender Member Since: 10 Jan 2014 Location: montchaton Posts: 7 ![]() ![]() ![]() |
where can I get hold of this magical Captain Tolley creeping crack stuff
Thanks in advance for the rply Walter |
epictrail Member Since: 21 Sep 2013 Location: High Wycombe Posts: 395 ![]() ![]() ![]() |
Thanks for your swift reply. I only hope that they are shipping to France. Can't wait to try it and will make my experience known
thanks again Walter |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
Didn't they print an updated water ingress manual?
I have the downloadable pdf manual, but I feel that I have to look further than what the manual gives me. So, I am banking on the Captain Tolley methode. Thanks for your post anyway
Walter |
the Captain Tolley is very good, but i now see that the water is coming in from further down the car, perhaps the top window in the middle. I might have to pull it out to check. I cant see any other holes anywhere in the back.
The window in the middle, you referring to the alpine windows? Capt Tolley will sort them out, just make sure it's been dry or a few days and there is no water in the gap. If there is if has the effect of watering down the sealant as it is water based.
