Home > Technical > Doors: Galvanised Vs Puma
Page 2 of 3 <123>
Porny
Site Sponsor
dnorrishill wrote:
Anyone know which bits will transfer from the older steel frame/ali skin to the newer all steel doors?
Will the winders, electric windows, handles, seals, glass, door card, etc. fit or are they different?
Door cards are different between pre 2004 and post 2004...
The internal plate/window carrier is different...
Every thing else is the same.
If it was me I would go for a late set of Td5 or Puma doors (which have a light galvanised coat as standard) - but get a complete set.
The problem with the galvanised frame version still has the issue of dis-similar metals when using the standard Aluminium skin.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #297450 10th Jan 2014 11:01am
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Ian, thanks for the info, very useful.
I did see on the SP site that they use galvanised steel skins on their doors for this very reason (these are the door that are made to pre 2005 design)
Post #297455 10th Jan 2014 11:15am
I.AM_a driver
Scotland 2002 Defender 90 Td5 CSW Oslo Blue
Thanks for that info Ian, clears up the guesswork without having to take apart anyones puma door for comparison Laughing
I doubt these come along for sale that often, the pair in the link posted eariler will probably go for silly money and I'd rather find some from a reputable salvage company than a private trader who cant verify their source. Mark S
CONVOY for HEROES
www.facebook.com/convoy4heroes
www.lothian4x4response.org
Td5 90
Thread in 'My Defender' Forum
Post #297651 10th Jan 2014 10:21pm
I.AM_a driver
I've decided to go for the Puma doors but I haven't come across anywhere that can supply them other than Land Rover themselves.
As per my post in the for sale/wanted section, if anyone has puma does for sale please get in touch. I won't be answering unless you are an established forum member, recently registered scumbags need not apply Smile Mark S
CONVOY for HEROES
Td5 90
Post #300329 19th Jan 2014 6:59pm
I.AM_a driver
By the less than overwhelming response I've got about doors, both on here and in calling specialist 4x4 or defender breakers, I'm considering replacing the doors with rocking horse poo or some hens teeth..... Big Cry Mark S
CONVOY for HEROES
Td5 90
Post #301028 21st Jan 2014 9:26pm
JWL
I'll bring you a bag of corn at Convoy then Mark so you can feed them when you get them Whistle
Post #301036 21st Jan 2014 9:39pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
I used one of the SP doors on my last 110, for the price it was good value , steel frame tho so it would need to be waxoiled etc.
The skin on the SP door is thicker than the standard land rover door, the fit was quite good too and overall it shuts with a nice solid clunk.
The real upside to the LR round top doors is the drainage at the bottom of the door frame is much improved, so no water traps and you can fit the newer tyre bottom door seal.
N.
Post #301051 21st Jan 2014 10:01pm
dnorrishill
One small ray of sun on the horizon, I emails SP again to get more details and got this response:
Quote:
hi david, the new load of doors we will be doing will also have a galv frame as well as well as the skin so they are actually going to work out a bit dearer than the ones with just the steel frame, we expect them to be about £50 each dearer as we have also sourced the manufacturer who made the door frames for land rover themselves so they will be basically genuine land rover frames that will be used, which is another factor why the new batch will end up a bit more expensive but the product will be even better being fully galvanised and with gen land rover frames
kind regards
william
Post #301063 21st Jan 2014 10:36pm
Tiger
http://www.keithgott.co.uk/parts_new_take_offs.html
Looky here
New take offs and you know they're not nicked Thumbs Up
Post #301103 21st Jan 2014 11:55pm
Martin
Site Admin
Also try Andy at AJS, I had a pair of Puma doors from him when mine turned to dust Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #301211 22nd Jan 2014 3:05pm
I.AM_a driver
Thanks Tiger, got in touch with them today so a pair of white doors will be on their way to my local bodyshop tomorrow for painting in 644 Oslo Blue Smile
Right, additional shopping list consists of full set of new seals (including the new design for the lower join with the sill), X-trouser latches, central locking actuators (they've started to play up), and when I'm transferring over my eclectic windows I think I'll need to repair the wiring as theres definitely a dodgy connection on the drivers door window wiring.
I take it that it's not too difficult to take apart the existing handles/locks and fit them to a new door? I'd like to keep the same locks if I can. Mark S
CONVOY for HEROES
Td5 90
Post #301517 23rd Jan 2014 4:08pm
JWL
Instead of replacing the window loom for another Land Rover one with the brittle wire syndrome, why not see about upgrading the wires for the windows and central locking for cabling that will withstand the constant flexing that the original cabling falls foul of. I'm sure that the wiring type has been discussed on here before on a few threads to do with central locking problems or get in touch with Vehicle Wiring Products and I'm sure they'll sort you out.
Post #301520 23rd Jan 2014 4:27pm
Tiger
Glad my constant trawling the web for Land Rover parts instead of working had been some use Thumbs Up
Post #301535 23rd Jan 2014 5:25pm
I.AM_a driver
And I had to trawl other websites to pick other bits & bobs that I will be replacing when I do the door swap, namely the door seals (inc the new design lower seals), central locking actuators, with X-trouser catches planned too.
You just take a door for granted until it stops working, drivers door is refusing to open now, probably in protest at the impending replacement..... Big Cry Mark S
CONVOY for HEROES
Td5 90
Post #302318 26th Jan 2014 4:19pm
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
I'd be interested Mark, in knowing what the total cost of going this route will be...my driver's door is in a bad way as well at the moment, and this is something I should definitely consider. 1998 110 300Tdi White Hard Top
Post #302323 26th Jan 2014 5:18pm
Page 2 of 3 <123>
