Home > Puma (Tdci) > Engine, Gearbox & Transfer Box Oil Change |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6264 |
Lou Sparts,
any suggestions on hose and funnel ie a hose small enough to fit into g.box and big enough for funnel to fit? thanks |
18th Dec 2013 8:52am |
cookware - there's an idea
I'll do a search today and see what I can find (will let you know). thanks again. |
18th Dec 2013 9:13am |
AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242 |
Cook and I both think the thing sounds quieter since I changed all the oils underneath. Gear changes are a little easier as well although they were pretty good before anyway.
I'm a bit of an oil fanatic and am now quite happy with what I've put in the diffs and g/boxes and can sleep soundly at night. AlanH. |
23rd Dec 2013 10:15am |
doublea Member Since: 12 Jul 2011 Location: Aberdeenshire Posts: 494 |
Just in the middle of my year 4 service and was wondering if the drain and fill plugs on the differentials and gearboxes require Hylomar or some other thread sealant?
1st Jan 2014 3:29pm |
On the diffs and T/Box I used a single layer of thread tape as they are a tapered thread but the G/Box had straight cut threads and no gasket of any kind, and were rammed in hard and took some effort to crack open. When refitting I used Permatex gasket non hardening sealant which has always done a good job in the past on drain plugs.
Cheers. AlanH. |
2nd Jan 2014 12:27am |
superspoons Member Since: 16 Apr 2012 Location: Herts Posts: 314 |
I found this today which I thought might be helpful when changing fluids :-
http://www.youtube.com/watch?v=sNFfdnfycYg Cheers, Superspoons |
16th Jan 2014 10:50pm |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2664 |
^^ good link, superspoons...
He used the "Laser Multi Purpose Mini Pump" (£17.99 from machine mart) oil pump for the gearbox. I tried that on the R380 box...it took absolutely AGES, but I gave up and bought the garden sprayer, and used the hook & pipe off the Laser Multi Purpose Mini Pump... If you have a compressor, you may be able to modify the laser pump to speed up the process. Interestingly he seemed to fill it, rather than measure out the correct amount... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
17th Jan 2014 8:58am |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 694 |
I bought one of these and did both gearbox and transfer box this afternoon. Great bit if kit .. if not a little expensive.
http://www.toollineuk.com/product.php/site...95/google/ 2008 Defender 110 XS SW - M57N2 / 6HP28X |
19th Jan 2014 8:32pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2586 |
Planning to change the gearbox oil (first time ever) and replace with Motul Gear 300, will post feedback once done and running. --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
20th Jan 2014 8:22am |
Right, so the gearbox now has Motul 300 in it.
First impressions after the 25km drive back home: there is definitely an improvement in the gear changes. Much less notchy, esp when cold and less clanging as well. Switched to Fuchs Titan SuperSyn F 5w30 After the first oil change to the Fuchs, my indie recommended that I change the oil again after 2000km to flush out any remaining Castrol. Engine is running very well -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
14th Feb 2014 9:50am |
Naks - have you had the spacer bushes done as per this thread:
http://www.defender2.net/forum/topic24561....n+bulletin I'm planning a 2nd gearbox oil change soon, but was going to get the dealer (I'm still under warranty) to install the spacer bushes first... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
14th Feb 2014 10:58am |
Ah, shucks. I knew I forgot something... --
14th Feb 2014 11:59am |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3612 |
Thanks to everyone whom has contributed to this thread, I followed the guide today and changed the oil in both axles, the gear box, transfer box and engine. Purchased an £8 garden sprayer from "the range" for filling up the gearbox (didnt need to add a hooked pipe on the end as I managed to get the spray wand to wedge under the car and into the filler hole). Used Gulf Competition Gear Oil from site sponsor Opie in everything except the engine. Used Castrol for the engine purchased when Halfords last had an offer on. All went well and took about 1.5 hrs all in. PS my Gearbox was T50 sized filler and drain plugs.
All future servicing will now be done by myself. DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
30th Mar 2014 8:36pm |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2724 |
I'm feeling the same, seems pointless to pay & get the extra piece of mind. Also gives you a chance to get that bit more 'intimate' lol Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
1st May 2014 11:15pm |
