Home > Puma (Tdci) > 2.2 Spin-on oil filter...
Page 1 of 5 12345>
Rick81
United Kingdom 2011 Defender 130 Puma 2.4 HCPU Galway Green
Well, having covered just under 2,000 miles in my new 2.2 I decided an early life/running in service was in order. Of to my local main agent only to have a call later to say its "sort of" done... We had to re-use the old filter as it is a spin-on unit and no one (including LR...) have any filters. Apparently they used to be element filters then went over to spin- on and are now back to element types (my vehicle is one month old) and they think there are 1,000 or so running around with spin-ons.
May be worth checking if you have a recent 2.2, the main agent thinks they may have to change the whole filter housing...
Post #283835 20th Nov 2013 9:03pm
AWOL
Are you sure there isn't one from a different vehicle that fits?
(Would be very surprised if there wasn't)
Post #283850 20th Nov 2013 10:02pm
Rick81
Maybe, but it is now a warranty question as apparently it is not just a question of one which fits but one that meets the required specification...
Post #283865 20th Nov 2013 10:32pm
AWOL
Indeed, but my money would be on there being a suitable alternative out there (there aren't a huge number of oil filter makers). Most likely a Ford type given the engine's origins?
I take it the dealer is proposing swapping the housing as a warranty job?
Post #283886 20th Nov 2013 11:07pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
not so much warranty but a recall 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #283892 20th Nov 2013 11:18pm
Cheshire110
maybe not such a bad thing if you can actually find a filter!
the push&twist ones are Censored  Cheers, David
Post #283894 20th Nov 2013 11:23pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
Why did they start the oil change if the parts were not all there in stock?
I assume they decided not to charge you- yes?
Steve
Post #283954 21st Nov 2013 11:24am
dgardel
Italy
Ford Transit (MK7) TDCi!!! for sure Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #283958 21st Nov 2013 11:51am
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
I service 3-4 Transit 2.2/2.4 TDCI's every week .. all 2011/2012/2013 ... never seen one with a spin on filter cannister - they all have the same bowl and paper element as previous models Question Guns and Landrovers .... anything else is irrelevant.
Post #283994 21st Nov 2013 2:08pm
dgardel
Italy
LR (now LR004459)
Ford (Motorcraft)
IID Pro MV License
Post #283996 21st Nov 2013 2:18pm
Dave-H
Yep, they are the current [and previous] filter element.
But rick81 says his vehicle is not fitted with this type, but a spin on cannister type ............ Neutral Guns and Landrovers .... anything else is irrelevant.
Post #284004 21st Nov 2013 2:56pm
big steve
Do you mean by spin on filter the filter that could perhaps go on the top of the engine I know some 3.2 engines I had had a spiny filter like the old td5 in the rocker cover cup holder 2015 2.2 tdci hardtop xs
Post #284012 21st Nov 2013 3:26pm
Rick81
Hi everyone, to be clear mine is fitted with a spin on filter like the old Tdi and V8 petrol engines were, not the element type that everyone thinks are current....
The dealer thought ( Embarassed ) that they had the right filter in stock, what was not very good was that they then put the old and damaged filter back on. The lady at reception told me that it was fine "they have a seal you know" and "I will chase it up next week" and yes they did still charge me full whack. When I got home and saw how badly damaged the filter was I emailed a very detailed complaint and stated that I intended to call land rover assist stating that my filter was damaged and leaking and I felt the vehicle not drivable..... Service manager on the phone explaining/apologising, had it collected this morning and a double cab demonstrator delivered for me to use (I was offered a range rover but said if I had wanted one then that is what I would have bought...).
Post #284084 21st Nov 2013 7:37pm
Rick81
Does anyone have an email address for LR customer services by any chance?
Post #284789 24th Nov 2013 3:46pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
On here. Dedicated Forum group.http://www.defender2.net/forum/topic24642.html Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #284815 24th Nov 2013 4:52pm
Page 1 of 5 12345>
