![]() | Home > Maintenance & Modifications > Wrap around diff guard challenge |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
Are we talking QT ones? I've fitted my own and can help with info. ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
If it's a QT style guard, then yes you need to undo a couple of nuts on the diff. Then slip the bracket over the bolts and align with the main part of the guard.
I used a trolley jack under the main guard to push it up so you can fit the bolt that joins the two parts together. Hope that helps. Cheers Simon |
Jonno1968 Member Since: 24 Oct 2013 Location: Leicestershire Posts: 245 ![]() ![]() ![]() |
Hi, from paddocks pm147. JJ
And the smaller plate is for the rear diff which is a spacer to clear the prop rotation, chances are you will need it. I did with mine. ____\We|Will|Win/___
deep down Member Since: 02 May 2012 Location: France Posts: 204 ![]() ![]() ![]() |
I bought the one form Paddocks as well. It dint' fit and required modification. I wasn't impressed with the quality.
As I remember you need to undo the brake hose bracket on top of the diff housing to pass the small bracket underneath. I din't fit it in the end. Just ordered a front and rear set from QT. PM sent |
Really...i aint faffing around modifying the bl@@dy thing. Where can i get QT from...are they expensive? Thanks.
QT for a front and rear is about £112 ____\We|Will|Win/___
charliebaja Member Since: 05 Aug 2013 Location: Surrey Posts: 211 ![]() ![]() ![]() |
The QT guard is very good and i would say better than most others, in that it has a guard that pushes the car up and away from the hazard. However i will say they are quite awkward to fit, but worth it in the end.
This is how i placed it on the car: You undo the top 2 nuts on the diff, slide the small plate onto the studs then loosely do the nuts up . Place the main guard on the bottom of the diff, with the bolts just hand tight and hold the small plate and guard together and fit the bolt through one of the 2 holes and tighten up; I used thread lock here as well. Then torque the bottom fixings of the guard to diff up and hey presto and it will guard your diff from the worst boulders. |
