Home > In Car Electronics > The definitive Defender ICE thread
Page 44 of 71 <123 ... 434445 ... 697071>
For a Sub you will need to take the power from the battery direct. There is no way the ISO loom wiring would take the current or be any good for that matter either. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #276292 24th Oct 2013 12:51pm
mees
Netherlands 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
OK, thanks.
than I will first start with the upgrade of the head unit and speakers.
May be than the sound is already good enough for me. If not, I can always place this sub woofer.
Post #276294 24th Oct 2013 12:58pm
Tiger
Got some gubbins to throw in
Post #276317 24th Oct 2013 2:00pm
mees - Best way to go. Thumbs Up you might find it lacking in bass a little of which if you do then a Sub should be your route to take after that.
Tiger - Nice little lot you've got there! Wink what have you got in there? _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #276352 24th Oct 2013 5:11pm
Tiger
That will be
1 Kenwood KFC-S503P 13cm component speakers http://www.justkenwood.co.uk/car-audio.aspx/kfc-s503p-speakers
1 Kenwood KAC-6405 four channel power amplfier http://www.justkenwood.co.uk/car-audio.aspx/kac-6405-amplifier
1 Kenwood KFC-S6974 6x9 speakers (pair) http://www.justkenwood.co.uk/car-audio.aspx/kfc-s6974-speakers
1 Kenwood KFC-E1064 10cm speakers (pair) http://www.justkenwood.co.uk/car-audio.aspx/kfc-e1064-speakers
1 Kenwood KSC-SW11 active subwoofer http://www.justkenwood.co.uk/car-audio.aspx/ksc-sw11-speaker
Thumbs Up
Post #276358 24th Oct 2013 5:20pm
That'll keep you busy then. Thumbs Up if you want a hand let me know, although I am sure you are more than capable yourself. Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #276360 24th Oct 2013 5:24pm
barbel jim
The 13cm components 'Up Front ?' Whistle
Post #276362 24th Oct 2013 5:38pm
Tiger
Yep, should squeeze them in
Post #276365 24th Oct 2013 5:46pm
barbel jim
I'm sure you'll probably have already read it but this might be of interest for fitting componants http://www.defender2.net/forum/topic23102.html
The only problem encountered was the cover in passenger footwell, over the wiper motor. It had to be persuaded out so the speaker ring would sit flat. Whistle Feel free to PM me should the need arise, but it is relatively straight forward. Good luck and............... Pictures Whistle
Post #276370 24th Oct 2013 5:59pm
Feeling like a good whistle there Jim. Whistle
Rolling with laughter _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #276383 24th Oct 2013 6:42pm
Tiger
Well I've just offered up the active sub to the back of the cubby box and it's a bloody perfect fit.
Looks like it was made for a Defender cubby box, super happy!
May take a photo later. Thumbs Up
Post #276393 24th Oct 2013 7:17pm
Excellent, need photos though. Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #276395 24th Oct 2013 7:20pm
Tiger
Not the best but you get the idea
Post #276402 24th Oct 2013 7:26pm
Tiger
It's dead flush to the sides to the mm
Post #276403 24th Oct 2013 7:27pm
Does look good doesn't it. Thumbs Up be careful with the fixings though.... Probably best to use some small blunts and nuts and not screws or they'll stick out the other side. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #276411 24th Oct 2013 7:38pm
