![]() | Home > Maintenance & Modifications > Rear Step Bumper 90 Additional Bracing? |
doublea Member Since: 12 Jul 2011 Location: Aberdeenshire Posts: 495 ![]() ![]() ![]() |
Just had a rear step bumper fitted by an independent land rover specialist, but notice the bracing bars from the hitch area to the rear chassis rails are omitted.
![]() I called about it and was told the 90s don't have these. I said I thought otherwise and would come and speak to them face to face. The rear step has a label "Styleauto Ltd"; I was under the impression that it would be oem spec. I thought it should have the bracing between the circled holes? ![]() Anyone know what it should have? |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Mine has the braces at the holes you have circled (will see if i have a pic). 2005 Td5 90 XS
Steve |
Thanks for your replies, Obviously I didn't try hard enough on Google!
I phoned Style Auto who confirmed the arms should be present. They have a wee website too: http://www.styleauto.co.uk |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698 ![]() ![]() ![]() |
It must have the bars fitted. An LR specialist should know better
pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 ![]() |
It is genuine Land Rover, I fitted mine at weekend with bracing bars
![]() They were in the box together with a drilled piece of metal that goes between the crossmember underneath & the L shaped bit that bolts up into the crossmember - Might be worth that is fitted ![]() |
http://topix.landrover.jlrext.com/topix/co...tabs=false
OEM fitting instructions available here. hard to miss them as they are solid and weigh a tonne. |
