Home > Maintenance & Modifications > Rear Step Bumper 90 Additional Bracing?
doublea
Scotland 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
Just had a rear step bumper fitted by an independent land rover specialist, but notice the bracing bars from the hitch area to the rear chassis rails are omitted.
I called about it and was told the 90s don't have these. I said I thought otherwise and would come and speak to them face to face.
The rear step has a label "Styleauto Ltd"; I was under the impression that it would be oem spec. I thought it should have the bracing between the circled holes?
Anyone know what it should have?
Post #273507 13th Oct 2013 9:07pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Mine has the braces at the holes you have circled (will see if i have a pic). 2005 Td5 90 XS
Steve
Post #273512 13th Oct 2013 9:22pm
leeds
A couple of points.
What is on the invoice? You suggest you believe LR/ OEM was to be fitted. Did you believe it should have been a proper genuine LR one, OEM or generic aftermarket? In general terms genuine LR is more expensive then OEM, which tends to be more expensive then aftermarket gear.
Personally I believe that bracing should be fitted.
However why not phone Style Auto on 01525 217705 and ask them?
Please remember that a vehicle registered as a commercial vehicle does NOT require type approved tow bar but a car does require type approved towing equipment since 1998(???) Another point to consider when you approach the garage which fitted it.
Brendan
Post #273518 13th Oct 2013 9:38pm
doublea
Thanks for your replies, Obviously I didn't try hard enough on Google!
I phoned Style Auto who confirmed the arms should be present. They have a wee website too:
http://www.styleauto.co.uk
Post #273606 14th Oct 2013 9:48am
Martin
Site Admin
It must have the bars fitted. An LR specialist should know better Rolling Eyes  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #273631 14th Oct 2013 12:05pm
pjb
It is genuine Land Rover, I fitted mine at weekend with bracing bars Thumbs Up
They were in the box together with a drilled piece of metal that goes between the crossmember underneath & the L shaped bit that bolts up into the crossmember - Might be worth that is fitted Exclamation 2020 P300 HSE
Post #273635 14th Oct 2013 12:28pm
http://topix.landrover.jlrext.com/topix/co...tabs=false
OEM fitting instructions available here.
hard to miss them as they are solid and weigh a tonne.
Post #273909 14th Oct 2013 11:03pm
